Previous in Forum: What is the Name of This Stopper?   Next in Forum: Carbon Pipe Spec x60 Vs. x65
12 comments
Location: Ganapthipalayam,Udumalpet,Tiruppur, Tamilnadu, India
Centrifugal Fan - Backward Inclined Type
02/01/2011 10:59 PM
please help to find out the performance of a backward implied centrifugal fan in therortical way.. it sucks air by radially and deliver it through axially
Re: centrifugal fan- backward inclined type
02/01/2011 11:07 PM
Good Answers: 183
Re: Centrifugal Fan - Backward Inclined Type
02/02/2011 7:50 AM
In a rotating wheel the air will move ONLY in centrifugal direction ! It CANNOT have a centripetal movement. So ALL centrifugal fans or compressors aspire at the shaft level and expel at periphery which ever direction you rotate the wheel and which ever direction the vanes are bend for or backwards. The only difference will be the efficiency since if it was designed for a rotating direction and it is used in the opposite the efficiency is not the same but a low lower.
Good Answers: 130
02/03/2011 2:45 AM
Not quite; A backward curved impeller will produce more pressure at less volume. A forward curve will produce more volume at less pressure. A 'paddle' is deemed the median performance. A biased 'S' curve is a common 'hybrid' improvement.
02/09/2011 12:43 AM
can u help to find out the mass flow of air taken by a fan with blade angle.? the fan type is axial-centrifugal backward inclined with conical back plate.
Good Answers: 130
02/09/2011 2:32 AM
Are you sure it's for air?
Water Jet drives have a conical/centrifugal impeller.
How about you post a picture of whatever it is you have?
02/09/2011 3:33 AM
yes it is for air only., this fan is used to dissipate the heat produced in the alternator . it sucks the atmospheric air through coin winding.
02/09/2011 3:39 AM
yes it is for air only., this fan is used to dissipate the heat produced in the alternator . it sucks the atmospheric air through coil winding.
Good Answers: 183
02/09/2011 3:53 AM
If the fan was manufactured you get from the manufacturer a graph flow/pressure difference. You simply measure the pressure difference and get the flow. You do not need to calculate.
02/09/2011 4:43 AM
sorrry sir, actually i want that calculation for compare the practical and theoretical way,. its required for my final year project work.
Good Answers: 183
02/09/2011 11:47 AM
OK then the best you can do since the computation requires a lot of fluid dynamics back ground is to take, as I already suggested, a good book and study how this has to be done. After you master the equations then you make a trial and communicate to CR4 your equations and your results and of course one of us will check it and make positive comments. At CR4 we have the basic rule NOT to make the work of students since it does not help them at same time we are willing to help when difficulties appear. For the analysis of your results it will be necessary to give as well all dimensions of the fan (rotor and stator) and rpm at which you made the measurements you intend to compare with theoretical values.
02/04/2011 4:31 AM
Hallo,
Another interesting thing is that the tip velocity is high in case of backward curved vane than that of forward or radial vane. Due to this reason backward curved vane impeller is used to handle dust or corrossive material laden gas/air with high effeciency in low RPM. Forward or radial vane impeller commonly used to handle clean air or gas and speed is high.
Suranjan Chattopadhyay
02/06/2011 10:37 PM
That is backward "inclined", not "implied". Here's some info on inline centrifugal fans by Greenheck: http://www.greenheck.com/products/detail/90
Hartzell makes the also:
In steel: http://www.hartzellfan.com/process-ventilation-equipment/steel-in-line-centrifugals/
Or Fiberglass: http://www.hartzellfan.com/corrosion-resistant-fiberglass-equipment/frp-in-line-centrifugals/
You might google Buffalo fan company, or Buffalo Forge Fan company, or New York Blower, or ACME Fan Company, or Big Ass Fan Company, etc, etc, etc.
Register to Reply 12 comments
34point5 (2); Anonymous Poster (2); basskar (3); lyn (1); nick name (3); Suranjan Chattopadhyay (1)
