Previous in Forum: MCB Construction   Next in Forum: MCB - Construction Vise
Running Different Cross Section Busbars For Phase
02/02/2011 2:07 AM
Greetings to all
Can we use different cross sectioned busbars in phase?
Example:
For 800Amps ACB shorting, we use 40X10 al. bb of 2runs or some times 50x10 al.bb of 2runs. Instead can we use 50x10 & 50x6 al.bb for each phase?
Is there any disadvantage of using these kind of constructions? Please clarify?
Prem
Good Answers: 170
Re: Running Different cross section busbars for phase
02/02/2011 5:45 AM
There could be unequal distribution of currents in these bus bars and the associated effects.
02/02/2011 5:48 AM
Can you please detail what are all those effects can be...?
Good Answers: 170
02/02/2011 6:13 AM
Different temperature rise, different thermal expansions, different forces, etc.
Re: Running Different Cross Section Busbars For Phase
02/02/2011 1:01 PM
At the ACB terminals standard practice is to exactly match the bus bar width to that of the terminals width.
(a) There is not enough clearance to accomodate a larger width bus bar at the ACB terminals.
(b) A smaller width bus bar will be a source of heating at the point of contact with the breaker terminals.
Thickness of the bus bars only can be increased or decreased to cater required current.
Knowledge sharing is a WIN-WIN situation
02/03/2011 2:00 AM
Similarly, Please be aware that power supply cable wires with defferent line length will create phase imbalance and wire overheating.
Good Answers: 128
02/03/2011 8:24 PM
prems4573,
The brief answers from electricalexpert65 are, in my opinion, correct. I am assuming that this is an AC application. I have been thinking about this before continuing--the only way to verify the suitability of this arrangement would be to do tests with an actual layout of the unequal bus bars. Certainly this would be required to pass short circuit withstand qualifications. Good luck.
--JMM
06/01/2011 6:07 AM
Theoretically, you can design such a bus bar system, but practically it will be difficult needing extra engineering effort in terms of travel and termination of such a bus bar system through a given switchgear. Moreover, both sizes (particularly the smaller size) must meet short circuit withsatnd capability criteria.
BB Raina
Register to Reply 7 comments
Anonymous Poster (2); BB Raina (1); electricalexpert65 (2); jmueller (1); mountk2 (1)
You might be interested in: Busbars and Busways, Leaf Chain, Fibre Channel Products
