Previous in Forum: Seminar subjects   Next in Forum: MCB for DC 28 volts
Calculation of Rotor Resistance in AC Servomotor
02/02/2011 4:47 AM
From the spec sheet of an ac servo motor, how can I get rotor resistance? The datasheet gives phase resistance which is almost zero. I understand that rotor has a higher resistance.
Re: Calculation of rotor resistance in AC servomotor
02/02/2011 6:03 AM
If you are well equipped with instruments,You can Use LCR Meter,Else use a Variac and pass few volts measure current and divide it with voltage. Regards, Rajan
Reply to Forum Thread
