Previous in Forum: Orifice Plate   Next in Forum: Transmitter Damping & Current Saturation
High-High Level Switch
02/03/2011 4:25 PM
Looking for a good dry contact type switch for a open atmosphere tank high-high application. The liquid is a high ph slurry mixture. any suggestions on style of switch? This will be used as a dry contact for PLC input.
Re: High High Level switch
02/03/2011 4:41 PM
Well here is a suggestion.
Good Answers: 58
02/03/2011 4:48 PM
If you can fabricate a simple support or there is existing means of support, I would go with a float switch. Simple, tried, and true!
If you are looking for a chemical resistant float switch try this link: http://www.grainger.com/Grainger/wwg/search.shtml?searchQuery=chemical+resistant+float+switch&op=search&Ntt=chemical+resistant+float+switch&N=0&sst=subset
Re: High-High Level Switch
02/04/2011 12:38 PM
  • Endress + Hauser "liquphant" (usual disclaimer).
  • Vega does something similar (usual disclaimer).
  • Etc., etc.
Good Answers: 11
02/17/2011 11:04 PM
http://www.ktekcorp.com/dnn20/Default.aspx?alias=www.ktekcorp.com/dnn20/ktek
Try to look on your requirements above
KJK/USA (1); Noudge79 (1); PWSlack (1); redfred (1)
