Previous in Forum: Proclainer   Next in Forum: Zero Access
Help with this Mechanical Engineering Calculation
02/05/2011 1:55 PM
Hi I'm doing an assignment and I need some help. My question is, A turning moment of 6Nm is generated by a force of 24N acting at right angles to a lever. What is the effective length of the lever in meters?
Re: Help with this Mechanical Engineering Calculation
02/05/2011 2:23 PM
The torque or turning moment acting on a body is defined as the product of the magnitude of the force and the perpendicular distance of the line of action of the force from the axis about which the body is being rotated.
You can manage the division sum....can't you?
02/05/2011 7:34 PM
OMG.........This is a new low.....!!!
Even for this third-world homework helper of a forum
Please, please.....in the name of all that is holy
Delete this guy !!!!
02/06/2011 2:54 AM
All the information needed to obtain the answer is contained within the question.
02/06/2011 3:31 PM
I hope you are still in high school, hopefully first year! Mathematically, this is expressed by M = Fd, where F is the force, d is the perpendicular distance between the force and the fulcrum, and M is the turning force known as the moment or torque. (F=24N, M=6Nm) Then (d=M/F) What are you going to do if someone asks you a real problem?
02/07/2011 1:07 PM
torque= perpendicular distance of force vector from the point of action * force applied
using right hand thumb rule find the direction of torque also if necessary..... hope this soves ur plob
Anonymous Poster (1); harsha_iit (1); philroth2252 (1); PWSlack (1); woodygb (1)
