Previous in Forum: Thickness Calculation for Piping as Per ASME.B.31.1   Next in Forum: Machine Size Scaling Question
15 comments
Gear Reduction for Electric Bike
02/07/2011 7:41 AM
I've tried searching for gear reducers for an electric bike motor but not having much luck. The motor spins at around 6,000 RPM max and needs to be reduced to 60 RPM (100:1 reduction). That is so the motor can drive the pedals at a similar rate of a cyclist.
There are already some methods used by e-bike enthusiasts, the most common being reductions using chains or belts. But I wonder why there is not much gearbox usage when there are so many different types of gearboxes available?
A typical motor is the Astro 3220 ( http://www.astroflight.com/index.php?main_page=product_info&cPath=9&products_id=123 ). It's original purpose is a remote control aeroplane motor but has been adapted to e-bikes.
Good Answers: 266
Re: Gear reduction for electric bike
02/07/2011 8:51 AM
Weight, cost and durability. When chain reduction will do. You will already using a gear and a chain.
Also the RPM of that motor is typical 6000 to 10000.
Re: Gear Reduction for Electric Bike
02/07/2011 9:48 AM
Misapplication of the technology leads to problems such as this. The model airplane motor is not designed to produce torque at low rpm because a spinning prop doesn't start using power until it's turning in the upper rpm range.
Not much help, I know.
Good Answers: 183
02/07/2011 10:15 AM
For same power the combination high RPM motor + reduction gear weights less than a high torque low RPM motor.
This is the reason for the choice.
02/07/2011 10:32 AM
OK, Thanks. I hadn't actually considered the weight factor.
02/07/2011 10:39 AM
I agree that motor is not going to last (Heating) and the loading if you have a side load is going to kill the bearings. Why not go on ebay and find a better choice as the gear box that your thinking about is way expensive, for I assume you want rpm in the hundred range as an output. Woody
Life is short, eat your dessert first .......In theory there is no difference between theory and practice. In practice there is. Yogi Berra
Good Answers: 48
02/07/2011 11:11 AM
For simplicity and robustness perhaps you should be looking at a wheelchair motor: http://www.emd.co.uk/productrange.php These incorporate a wormdrive rightangle gearbox, quite simple but robust.
These days people seem to be going more for brushless, gearboxless dc motors (even for wheelchairs) for lower weight, longer life and better efficiency: http://www.goldenmotor.com/ I haven't looked at these in detail, but assume (for low-speed torque) that they are more akin to stepper motors or dc servomotors than the usual BLDC.
02/07/2011 3:37 PM
A simple option is to use a right angle gearbox that uses a worm gear type of reduction system. They are considerably more forgiving than most other gear reduction systems to having their inputs ran at high speed while still providing a reliable high speed reduction ratio in a small package.
I have seen a number of them re purposed to unusually high input speeds with little more than a change out from the original thick heavy gear lube to a thinner lightweight synthetic lube.
The rest is just a matter of staying inside the design torque specs.
Good Answers: 183
02/08/2011 4:15 AM
From simplicity point of view your suggestion is the best but for a bike also transmission efficiency is important and from this point of view worm reductions are by far not the best. I think that a combination of chain/belt + gear would be the most efficient and as well will offer the lowest weight. Of course it is not the cheapest.
02/08/2011 4:24 AM
Thanks for the responses, it's a very informative forum.
What spured me to investigate gearboxes was that I saw someone offering to build a chain reduction drive within a case on one of the e-bike forums. It was fully enclosed and was basically just a sprocket & chain reduction inside.
It seemed strange to me because it's kind of simulating a gearbox. Apparently the efficiency with a chain is around 95% too whereas some of those worm gearboxes are much lower. But if that is the case you'd think people would be using chain-drive gearboxes in other applications? I haven't tried searching for them although I have heard they exist. But are they very popular?
Good Answers: 48
02/08/2011 5:23 AM
The efficiency of the chain reduction drive is very good, but they can be extremely heavy compared with other methods, maybe not so good for a bike.
Good Answers: 183
02/08/2011 5:50 AM
In earth drilling units (stationary) such transmissions with heavy quadruplex chains were used and with good results. For low power the solution is not optimal.
Good Answers: 114
02/08/2011 11:18 AM
02/08/2011 12:52 PM
Why not try and find a small, low voltage 3 phase motor and drive it via a VFD?
Good Answers: 58
02/08/2011 3:55 PM
My favorite is still the Cyclo drive for a lot of reduction in a simple compact unit.
mike k
02/09/2011 6:56 PM
hi if dc a simple use of a ballast cappacitor and transistors can be used but will only give prefferd rpm when under desired load but benefitting from high tourqe as if running at full speed.
Register to Reply 15 comments
Andy Germany (1); Garthh (1); Holzfeller (2); LegendLength (1); lyn (2); mike k (1); nick name (3); ohmslaw (1); ozzb (1); tcmtech (1); waldig (1)
