Previous in Forum: Cheap Solar Panel System   Next in Forum: 17-4 ss
Location: Taiwan Road, Caomiaozi Town, Weihai Industrial District, Weihai City, Shandong Province, China
Wanted: Straightener for Thin Tungsten Wire (Below Dia. 0.5mm)
02/07/2011 10:48 AM
Now, we are producing straightened tungsten wire, and we often find the wire is not straight after it pays off from spool. for the thin tungsten wire, below 0.5mm diameter, it is difficult for us to straighten. can you help me to provide method or equipment to do that?
Chanllenge current Tech for our Blue Sea in Tungsten field. Dr. Kasten Li
Pathfinder Tags: straightened tungsten wire
Good Answers: 97
Re: wanted: Straightener for thin tungsten wire (below Dia. 0.5mm)
02/07/2011 11:43 AM
Try googling "straightening wire" there are machines available that can do this. I bet there is even one manufactured in China.
Spring winders must first straighten the wire to wind the spring.
CRTL-Z
Re: Wanted: Straightener for Thin Tungsten Wire (Below Dia. 0.5mm)
02/07/2011 2:51 PM
Why not just put it onto a larger diameter spool in the first place: you only have to avoid going beyond the elastic limit.
02/07/2011 10:54 PM
Hi,
I have just posted a question last week regardinng 0.3mm tungsten wire.
I am interested in your comments regarding the breakage of tungsten wire.
I use arround 100Kg a year. Some parts of the wire keeps breaking(approx 10% of my stock). Having 4 machines that coil the wire around another wire which is 1mm in diameter I can easily prove to myself the wire is faulty. My question to you is are you able to point out some causes why the wire would break? annealing etc?
"A designer knows he has achieved perfection not when there is nothing left to add, but when there is nothing left to take away."
02/08/2011 1:39 AM
You may wish consider annealing the wire in an inert atmosphere after mechanically straightening it. I cannot recommend any particular equipment that does this, but if your wire has been stressed by bends or kinks, it is much more likely to fail due to metal fatigue and/or thermal shock. Something to consider whilst looking for suitable equipment. You may also try a completely different approach: find a vendor who does *not* supply you with poorly-wound/defective reels of fine tungsten wire. Avoiding the problem in the first place is nearly always the preferred route. There are ways to wind reels of fine wire so that it pays out without kinking, and there are ways not to. As the first step my suggestion to you is to locate a vendor who specializes in the former. -e
Good Answers: 94
02/08/2011 4:12 AM
Use a wire straightener. There are several makes & styles available.
02/08/2011 4:29 AM
Thank you very much!
11/21/2018 11:46 AM
I would agree find a wire straightener which model would depend on the diameter of the wire. Their are many variations but most work the same with the number of rollers being the difference. You could look to have a whole turnkey system with dereeler, straightener, feed system and cutting heads. Again these wire cutting machines can come with many different options, look around and I'm sure you will find what you need.
Register to Reply 7 comments
Anonymous Poster (1); cool (1); multicrystal (1); Nigh (1); Randall (1); scottk1016 (1); Unredundant (1)
