Previous in Forum: Transformer Bank Loads   Next in Forum: Motor Amps
11 comments
Location: Far above all principalities and powers. Nigeria
A Little Confusion on Surge Arresters
02/08/2011 1:54 AM
Hello People, Kindly help clarify. I am working on the BOQ of a particular HT Transmission line and substations project. One of the specified items is Surge Arrester Earthing. This is a little confusing. The truth is physically I have not really had any involvement with any such equipments. My question is does a Surge Arrester have Earthing cable materials for its connection that are purchased separately or is there an error? Can anyone help me with a picture or something of the connection between the surge arrester and the equipment (HT Cable and/or HT Transformer it is protecting). Please help needed urgently, I'm at a standstill. Thanks in anticipation and Best Regards.
Re: A Little Confusion on Surge Arresters
02/08/2011 2:12 AM
You can please explain from this diagram. Are those cables separate items for purchase?
02/08/2011 4:10 AM
You have to procure earthing conductor (ECC) and fabricate earth pit, surge arrester supplier will not arrange these for you.
Your picture #1 is a pole mounted transformer and I am seriously doubtful that this would be the case in a T&D substation.
Picture #2 is barely symbolic, instead of fuse you will encounter CB and Isolator, as a standard practice you cannot common transformer and arrestor ground conductors and I expect that in a T&D substation the arrester will be separately mounted on a post / structure instead of transformer frame.
You can check the websites of prominent manufacturers like ABB, SIEMENS, Alsthom GE etc. to see the immages. Just go to www.google.com and make a search for the surge arrester.
Knowledge sharing is a WIN-WIN situation
02/08/2011 4:19 AM
Thanks for the info on the earthing conductor, maybe that's what the clients mean by "surge arrester earthing". " You can check the websites of prominent manufacturers like ABB, SIEMENS, Alsthom GE etc. to see the immages. Just go to www.google.com and make a search for the surge arrester." ...I have seen different images from the various sites, but they dont seem to show the wiring connections.
02/08/2011 5:40 AM
Hire a subcontractor.
Just a minor job like an earth wire run from the motor frame, in the present case you will have to connect the ECC to a terminal at the bottom of surge arrester and will go up to earth pit.
08/19/2011 12:08 AM
I have seen separate earths for lightning arrestor,transformer neutral and transformer frame. Verify from your utility.
pnaban
Good Answers: 181
02/08/2011 4:33 AM
Phone the Surge Arrester manufactuer
02/08/2011 9:23 AM
Dear Toba,
Viewing your previous posts including thing one I think our Job Descriptions are alike. .
For Surge Arresters Earthing you would require the following:-
Earth Electrode
Supply and Installation of copper weld earth electrodes, 3 meter long and 3/4'' dia. Driven vertically in ground including the cost of concrete pit all necessary material complete in all respects and conforming to general specification
Earth Test Clamp
Providing, installing earth test clamp made of copper for each down tape. The earth clamp to be installed 5 ft above ground. No connection shall be made to the earth tape below the test clamp
The Crazy Man Talks and The Smart Man Understands
02/09/2011 12:33 AM
How do we know that the lifespan of a surge diverter has expired or damaged?.
pnaban
02/09/2011 1:21 AM
I agree with mountk2 that the surge arrester should not be earthed via the transformer tank as this could create serious problems in the transformer in the case of a lightning strike. After all we are trying to protect the transformer.
The earth connection may be made to the substation earthmat as opposed to building a new earth pit.
The cabling will not , normally, be supplied with the surge arrester.
In order to assess the life remaining in the arrester an event recorder can be interposed in the line from the arrester to the earth these units are readily available.
02/09/2011 3:53 AM
I agree with#8 and also I would like to say :
1-You can check also the web site for companies spechialized in earthing systems.
2-In case of considering the number of events as an indication for the arrester life , please note that the surge arresters are usually provided with surge counter and which can help for the number of surges instead of using event recorder with cost pluse to the system price.
MKHALIL
02/09/2011 5:10 AM
Thanks everyone! I'm really grateful, I understand better now.
Register to Reply 11 comments
DamnGud EE (1); Forbes (1); mkhalil (1); mountk2 (2); pnaban (2); Toba (3); TonyS (1)
