Previous in Forum: Cables   Next in Forum: MCB
8 comments
Earthing Plate Calculation
02/09/2011 1:06 AM
Dear All, Hope you are doing good!! i m working on the earthing system of 2 MW at 400V power plant therefore request you to kindly share with me how to calculate the proper size of earthing plate & earthing rod.
CR4 Admin - email address removed
From the Site FAQ: Do not post phone numbers or email addresses. The CR4 Admin will delete all phone numbers posted in threads or comments, and we strongly urge you not to put up email addresses. You can share this information via the CR4 internal messaging system.
Re: Earthing Plate Calculation
02/09/2011 1:27 AM
An acre will be plenty, no matter how crummy the ground conditions are.
02/09/2011 3:57 AM
You should know the fault level.Is it islanded or connected to grid?.
pnaban
02/09/2011 4:10 AM
Better to deput consultant and get the calculation approved by client, earthing is not a child's play, it can create a havoc if not done properly.
BNDas
02/09/2011 7:14 AM
Hi,
Refer to query, if this matter is for the construction site building new substation, i would suggest refer back to your main contractor or the designer, ask them to issue the aprroved design before constructing anything.
Regard's
Good Answers: 116
02/09/2011 9:58 AM
  1. Do you have a value of resistance which must be met according to a site specification?
  2. Earthing can vary from easy in a sea harbour to impossible in a bone-dry silica sand location.
  3. Executing a sound, durable earthing system is very dependent on the durability of materials and joints in initial installation and after years of corrosion.
  4. There are companies e.g. Furze in UK, who specialize in suitable equipment and design requirements - you would be well advised to consult them and buy from them.
  5. There are standards for earthing e.g. British Standard 7430.
02/09/2011 2:04 PM
Tornado said "An acre will be plenty, no matter how crummy the ground conditions are."
The guy is installing a 2000 kva transformer. Why would you go to such extremes? Why not a 10 ft ground rod, #6 cu, and use the building steel as an electrode?
02/09/2011 3:03 PM
I was being facetious, along the lines of what can be calculated vs what one looks up in code or manufacturer tables.
02/09/2011 4:49 PM
OK Mr T. You got me. It seems like a simple problem.
Register to Reply 8 comments
67model (1); biswanath.das (1); pnaban (1); ronron (1); Tornado (2); wareagle (2)
