Previous in Forum: 33kV ACSR Overhead Line's Parameters   Next in Forum: AC Generator Rotating Rectifier Diodes
CTs on a Double Bus Section
02/09/2011 11:42 AM
What can cause a CT to fail especially on your one phase on an open bus section? Can it be insulation? And since the bus coupler is open how does it affect your CT's Thank you
Pathfinder Tags: CT's
Good Answers: 181
Re: CTs on a Double Bus Section
02/09/2011 4:34 PM
Most bus-section CB's don't have CT's so this must be a special case. What voltage is it at? Insulation break down on low / medium voltage is unusual, I think in 35 years I've only seen one and that was due to carelessness by a tradesman.
02/09/2011 8:36 PM
In 11KV side we had a 100/5A CT to an over current relay setting of 6.5 which means CB trips at 6.5A but CT is rated for 5A only in secondary.
Resulting insulation breakdown.It was an old kind of CT 40years old 30cm^3 size.
Then the relay settings were adjusted to optimum.
02/10/2011 3:28 AM
Wots that to do wit da price o fish?
Register to Reply 3 comments
