Previous in Forum: Are PRV's an Absolute on Centrifical Pumps?   Next in Forum: Mechanical Design
Radiator Connections
02/09/2011 10:48 PM
Why is use of make-up/fill line connection in a radiator ?
i think it is for positive suction in the pump but i have observed that many a times the make-up connection is not present,especially in radiators used for smaller HP engines.What if this connection is not given ?
Note :The radiator is used for stationary application not automobile...
Good Answers: 181
Re: radiator connections
02/10/2011 3:49 AM
Note, go back and look at your question and then think again.
02/10/2011 3:54 AM
is the reason of positive suction for water pump correct ?
02/10/2011 5:47 AM
The 1400cc engine fitted to the Volkswagen Polo does not have a top-up connection. If the fluid level requires topping-up, then it goes in via the radiator cap when the engine is cold enough to open it without risk of injury.
Good Answers: 266
02/10/2011 8:31 AM
The coolant is a hazardous substance. The make up tank is a collection point for any that blows by the pressure cap on the radiator. In the past we just dumped it on the ground. Hose ran off it down the side of the radiator and expelled any fluid that made past the cap into our environment. The tank also provides a inspection point to see if the radiator is full with out the hazard of opening it up with a hot engine as it's under pressure. This is not a sure inspection but the idea is as the fluid expands and contracts in the radiator it will expel and draw from the tank. So if there is a good fluid level in the tank you can be reasonably insured that the radiator has fluid.
The pump suction has nothing to do with it. The fluid level is above the suction of the pump so that provides positive input.
Smaller engines also have different maintenance to be preformed on them as stated by the OEM. More frequent checks of fluid levels as stated in the daily operation check list. The radiators are smaller so there is less fluid to expand. So there not as much need for the tank.
Anonymous Poster (1); ozzb (1); PWSlack (1); TonyS (1)
