Previous in Forum: Search for Roll Gap Checker   Next in Forum: Pressure vs Vacuum
Flashback Arrestor in Gas Welding
02/10/2011 6:11 AM
I have a discussion about the usefulness of the flashback arrestor, comparing with the non-return valves. How is it possible to have fire in the fuel hose or the oxygen hose, when you use an oxy-fuel torch?
Could the fire exist inside the hoses, while there is fire on the torch nozzle? I don't think so.
If the operator does not follow the correct procedure for starting or ending the work, then mixture could built up inside the hoses. That's why the non-return valves exist. To prevent the reverse flow.
So why do we need the flashback arrestors? As a sefety device in case the non-return valves are failed, or for a reason indepentent from the failing of the non-return valves?
Re: Flashback arrestor in gas welding
02/10/2011 7:12 AM
The last thing one wants is a fire going on inside the cylinders!
The purpose of the fire arrestors is to provide a point where a flame travelling backwards inside the hose is stopped before it gets to the cylinders. A non-return valve cannot do that.
Re: Flashback Arrestor in Gas Welding
02/10/2011 9:00 AM
The flame can travel backwards, only if mixture of oxygen and fuel is made.
If non-return valve functions ok, then mixtrure can not be made, so flame can not travel back. Am I wrong?
02/10/2011 10:17 AM
Non-return valves cannot be relied on to snuff-out a flame. Purpose-designed flame arrestors can.
Good Answers: 21
02/10/2011 10:20 AM
Any valve that operates as a check valve system can in fact work very well to prevent flashbacks from occurring. But, if for some reason you were to introduce an explosive mixture such a acetylene to a higher PSI then it cn handle (such as 40-60 PSI oxygen) it can in fact explode and cause fire in hose, etc. It takes little to make a very usable set of tools such as O/A torches one heck of a bad tool. Use the flask back arrestors and stop worrying why or how they work.
02/10/2011 11:44 AM
While using Oxy-acetylene cutting torch, you might have heard of " back fire" due to insertion of spark or spatter through nozzle holes of cutting torch while working in encloser or making holes in thick sections or cutting of thick sections from where molten metal is not flowing properly, that type of fire can travel through hoses and history knows it well. NRVs can stop the reverse flow but can not cut of fire.
Anonymous Poster (1); fixitorelse (1); Mukesh0861 (1); PWSlack (2)
You might be interested in: Gas Valves, Industrial Valves, Solenoid Valves
