Previous in Forum: Relationship Between Design Thickness and Corrosion Allowance   Next in Forum: Standard or Code
12 comments
Good Answers: 67
Problems of Slurry Handling Pump
02/11/2011 4:14 AM
Frequent bearing failures and vibration problems are experienced in a 275 kW centryfugal slurry pump. It has 20" size lengthy underground discharge pipe, which has reduced to almost 8" internal diameter due to heavy scaling. Can any one say whether the scaling in discharge pipe can cause problem experienced.
Pathfinder Tags: scaling slurry pump
Re: Problems of slurry handling pump
02/11/2011 5:40 AM
Good Answers: 137
02/11/2011 5:52 AM
I would say probably yes. Unless the 20" pipe was grossly oversized, reducing it to 8" will make a big difference.
Is the flowrate still adequate? Has the power drawn by the motor changed? What is the ΔP across the pump, and how does this compare with design and the pump curve? Is the suction pipe similarly scaled? Is the impeller badly worn so out of balance?
Checking above will help point you in the right direction.
Cheers.......Codey
Good Answers: 48
02/11/2011 6:14 AM
Good points so far. Just to expand:
The change from 20" to 8" could make an enormous difference to friction losses, and thus to system head, especially if the discharge pipe is long. The increase in head would have the effect of moving the duty point on the pump curve towards the left. If it moves far enough, it could move into the danger zone, usually considered about 0-20% of Best Efficiency Point, and this could lead to vibration and bearing failure.
If there is similar scaling on the suction side, this could drastically reduce suction pressure and NPSHa which could, as woodygb implies, lead to cavitation. This could cause damage to the impeller, as well as vibration and bearing failure.
As Codey indicates, wear or damage to the impeller & subsequent imbalance could cause vibration and bearing failure.
It could be a combination of the above, and there could be other factors (hard to say without seeing system diagrams), but you really need to clean or replace the pipework if it is that bad.
Re: Problems of Slurry Handling Pump
02/11/2011 2:09 PM
What do you think would happen if you plumbed twenty inch valves on the intake and discharge sides of your pump and then closed them both by 60%?
02/11/2011 3:16 PM
84%?
Good Answers: 181
02/11/2011 11:08 PM
To be honest high pressure water jetting of the pipe work is the only answer.
Been there and got the T-Shirt!
Good Answers: 117
02/12/2011 4:29 AM
now you know that the ID of the discharge pipe is reduced you have two options, replace or try jetting as one answer suggested.
Once your pipe replaced or jetting/cleaning has restored your pipe ID, try chemical scale inhibitor. However before you do, get a sample of scale analysed, so you get the right sort of inhibitor.
Prevention is way better than a cure and usually cheaper too!!
Good Answers: 48
02/14/2011 6:38 PM
How bizarre! I was sure I had a GA here last Friday night, and now it's gone. Either I was mistaken, or some petty minded gutless worm has been delving out OTs. Not that I'm bothered by GAs and OTs, I've learnt nothing from them during my short time on CR4, whereas I've learnt a lot from having my views challenged and particularly from having my misconceptions, misunderstandings and downright ignorance corrected by those who know better (you get over the dented ego once you realize you've learnt something useful).
If I post something that is incorrect or irrelevant I would much prefer it to be challenged, with explanations, rather than surreptitiously OTed. Likewise, when I challenge someone who has posted ridiculous statements I expect them to justify their statements or admit their mistake. Those who don't have the guts or the knowledge to behave this way shouldn't be posting in the first place. We learn nothing from it.
Good Answers: 117
02/14/2011 11:43 PM
Well thats told us all..
aren't we gutless.. ever thought that someone might know more than you, you've pissed someone off, or you are just not a nice person.
judging by your rantings, you are not.
So if you've learnt nothing from this collection of people who offer only opinions based on years of experience, then don't bother to grace us with your presence.
I was going to reply to your questions from another topic ref, centrifugal pumps, but now I'm not going to bother, becasue as you've just stated you'll learn nothing.
In my humble opinion, I think you are unteachable, with a closed mind, who want to impose unrelated thoughts, inexperianced and misguided ( and i used this term loosely) enginerring theories on people in these forums.
I think you have no experiance or real working knowledge of the subject you profess to know.. I have seen you posts.. you regurgtate the same words on the same subject.. and with no idea of really what you are saying.. and after reading your previous posts.. I am right. you know something, but have no idea how or when to apply it. That is due to a lack of experience.
so if CR4 can do nothing for you... byee!!
ps.. I scored your ranting OT and mine just to save you the trouble!
Good Answers: 48
02/15/2011 5:38 AM
Thanks for responding, brich.
I don't set out to piss people off, and I'm sorry if I've done so. In fact, I'm normally the lily-livered sort that tries to avoid conflict wherever possible. I don't make personal attacks on people, and I don't see why questioning the validity of someone's statements should piss them off. It shouldn't be taken as a personal attack, just an attempt to reach the truth. It's not uncommon for us to be asked to justify our statements. In the end it is a win/win situation, someone has the warm glow of being proven right and someone has the warm glow of having learnt something useful.
"ever thought that someone might know more than you"…" So if you've learnt nothing from this collection of people"… You seem to have missed the entire point of my 'rantings'. I stated quite clearly that I've learnt an awful lot from this forum, both from general reading of threads and from having my own misconceptions corrected by those who know better. But if the dialogue doesn't take place, then nobody learns and nothing is gained. If I'm wrong about something I would prefer having it pointed out to me rather than cruising along in blissful ignorance.
"In my humble opinion, I think you are unteachable, with a closed mind" etc. It's not me that insists on stating a "fact" and then refuses to enter into a discussion about it. And if I have made any statements that you think are incorrect, please point them out, don't just OT the post. I've already said I welcome being challenged. I can't lose, either it's proven I was right, or I learn something. All of the great scientists have been proven wrong somewhere along the line, even Newton and Einstein, and the best of the gurus on CR4 will acknowledge when they are wrong.
I don't think you can question my experience and knowledge of pumps, having spent almost a quarter of a century involved with chemical process centrifs, peristaltic pumps and gear pumps. I don't claim to be a pump guru, there is certainly still more I don't know than what I do know, but I'm happy to pass on what knowledge and experience I have. I don't intend to knock your knowledge and experience, nor to OT any of your postings no matter how incorrect or inappropriate they may appear to me. HOWEVER, I will question something that doesn't fit with my understanding of things, not in order to be vindictive, but in order to ascertain the truth through dialogue.
I don't go for the arrogant soapbox preachers of "the facts", nor the self-satisfied "this is a lesson - we will teach them the truth whether they like it or not" approach.
Rather than wasting our time on this unsubstantiated nonsense, I would rather you substantiated the statements I have questioned , and challenge me on statements of mine you think are incorrect. And it can still be done in a friendly manner.
Good Answers: 67
02/22/2011 3:12 AM
Thanks all for your valuable answers. In fact I could not provide informations like discharge flow, pressure, etc. to compare with rated, because measurements are not available. Reduction of internal diameter from 20" to 8" what I had mentioned is based on observations at few locations. Later on we found that the same reduction is not through out the length. Water jetting as some one suggested is difficult because of lengthy underground piping with several bends. Now, we decided to replace the entire discharge piping preferably overhead. Thanks once again.
Good Answers: 137
02/22/2011 5:25 AM
OK Pritam, thanks for coming back, quite often no more is heard from the OP so we don't know whether any of the suggestions are useful or not.
The pipe would only need to be reduced to 8" in a few places to make a big difference to the flow characteristics.
When you've done the pipe replacement please post the results.
Cheers.......Codey
Register to Reply 12 comments
brich (2); Codemaster (2); Doorman (1); Holzfeller (3); lyn (1); pritam (1); TonyS (1); woodygb (1)
