Previous in Forum: Machining Small Circlip Grooves   Next in Forum: Problems of Slurry Handling Pump
Relationship Between Design Thickness and Corrosion Allowance
02/11/2011 3:53 AM
Dear Colleagues,
Pls, get me cleared on the relationships between design thickness of and the corrosion allowance. Is corrosion allowance imbedded in the design thickness or does it given separately?
Thanks
Good Answers: 137
Re: Relationship between design thickness and corrosion allowance
02/11/2011 5:43 AM
It depends on how you define design thickness. Sounds like you're talking about pressure vessels.
The final thickness is that required to cope with the material stress (calculated from pressure, vessel diameter etc) plus the corrosion allowance (typically 1.5 or 3 mm, usually specified by the end user).
Whether you call the design thickness the one before or after adding the corrosion allowance is up to you.
Cheers.........Codey
BTW aren't you being a bit presumptuous with "Dear Colleagues" on your first post?
02/11/2011 12:04 PM
Good answer! BTW a colleague is by definition an associate, you made him one by answering him, or are you taking exception to "Dear"?
Good Answers: 137
02/11/2011 2:51 PM
Thanks for the GA.
My comment about colleague was meant as a joke, but if I made him one by answering, up to that point he wasn't one, the way I see it.
Cheers........Codey
02/11/2011 10:06 AM
Separately.
Otherwise, once the full corrosion allowance has been reached the material is then that amount under the design thickness.
Re: Relationship Between Design Thickness and Corrosion Allowance
02/12/2011 1:43 AM
From ASME or any other code, the required thickness of straight sections of pipe or vessel, shall be determined in accordance with the equation tm = t + c
where,
tm = minimum required thickness, including mechanical, corrosion, and erosion allowances.
t = pressure design thickness, as calculated by the code equation (depends on design pressure, design temp., material and diameter) for internal and/or external pressure.
c = sum of the mechanical allowances (thread or groove depth) plus corrosion and erosion allowances.
Abdel Halim Galala (1); Codemaster (2); philroth2252 (1); PWSlack (1)
