Previous in Forum: A Better Way to Combust That Car Engine.   Next in Forum: 1998 Dodge 2500 Diesel Hard Start When Cold
Rear Window Defroster Broken Help
02/11/2011 1:47 PM
Hi all
I have a problem. My rear window defroster is broken.
the only idea I have was soldering but that won't work because it heat up to defrosted the window and it would melt.
Would brazing work?
Can you halp me out be give me some ideas of what to do.
the world is what you take from it, so take it all!
Pathfinder Tags: rear window defroster
Re: rear window defroster broken. help
02/11/2011 2:01 PM
Google window defroster repair. Your local auto parts house will have a kit. They use conductive adhesive.
Good Answers: 123
Re: Rear Window Defroster Broken Help
02/12/2011 12:10 AM
There are 2 types of repair kits that I am aware of. One is for the repair of the grids that run across the window glass. the other is designed for reattaching the connector wire to the glass. Both are available from NAPA stores. I believe they are manufactured by Permatex. Good luck.
Bob
02/15/2011 1:48 PM
thanks for the help. you can close this forum now.
Good Answers: 123
02/15/2011 3:01 PM
DID YOU GET IT REPAIRED?
Bob
02/19/2011 8:28 AM
I dont think you can repair it
brazing will will be too hot and break the window
conductive paint in my experience doesnt last
you could try glueing a new connecter onto the good part using conductive glue
google " Conductive Glue"
Anonymous Poster (1); bob c (2); Ice-Man (1); lyn (1)
