Previous in Forum: Is there any Positive / Non-friction Continuously variable transmission....?   Next in Forum: Rear Window Defroster Broken Help
100 comments
A Better Way to Combust That Car Engine.
02/10/2011 3:30 PM
A theoretical engine design that could be made today with existing technology. This engine differs from most in that it doesn't have a traditional valve train. No cam, lifters/followers, rockers or heavy return springs. The valves are actuated with high voltage bidirectional solenoids. The only spring pressure is a light return spring vs. a traditional engine's 60-100 PSI seat pressure. Elimination of massive spring pressures that must be overcome constantly greatly enhance efficiency. Because the valves are not limited by the geometry of a camshaft engine they can be configured in any orientation to maximize chamber shape. Side by side, 90 degrees, 180 degrees, etc. The valves are of course operated by an engine management system. Fuel is delivered through direct injection to the chamber. The engine doesn't rely solely on the piston to compress air. Only the last bit of the upward piston stroke is used to achieve final compression. The bulk of the compression is done externally to the chamber. A compressor/blower coupled to a DC motor provides the engine with the desired compression for any given circumstance. The DC motor ramps up or down to meet demand. The combustion chamber has a transducer or other pressure sensing device to sense cylinder pressure every stroke. With this arrangement almost any compression ratio can be achieved from 6:1 to 13:1 on demand. Traditional engine have a fixed compression ratio. Power and economy all in one. No loss of turbo wasting or excessive compression with traditional forced induction. Since the valves are electronically actuated they do not follow a traditional calculus curve by following a cam lobe. Their lift is constant but duration is modified for any given power or economy operation. This allows a smaller displacement engine to have high compression and cylinder filling of a race engine one moment and a thrifty gas saver the next. The engine is also unique in that it operates on two strokes rather than four. As the combustion stroke hits BDC the exhaust valve fires open (not slowly ramping on a cam lobe). As the piston rises it pushes out the spent charge. A small amount of Intake air is introduced (no fuel yet) to finish burning any unburnt fuel and also acts to purge the chamber. The exhaust valve closes with the piston roughly 3/4 up the cylinder. Filling and injecting fuel at the same time until the desired charge is reached. The intake valve closes just as ignition takes place and the piston begins it downward power stroke. This engine fires twice as fast as a four stroke. Big power and a completely tunable engine make this format unique and worth a discussion.
User-tagged by 1 user
Re: A Better Way to Combust That Car Engine.
02/10/2011 3:36 PM
Sounds great.
Where can I buy one?
02/10/2011 3:48 PM
First question: will the dc compressor take more energy to run than will be saved by removing camshaft and valve springs? Why not drive it with a belt and do away with conversion losses?
Where will the surge tank be located; how much volume required?
Why do you need a light return spring if you have hi-voltage solenoids? How much power will be required by solenoids?
I have to do some real work now.
Bye.
02/10/2011 3:58 PM
I'd rather combust the fuel than the engine....
An amusing combination of intriguing ideas and hype, the latter of which would be best toned down.
Good Answers: 266
02/10/2011 4:51 PM
Many of the auto makers have been working on just that. Problem is the frequency in which the valve needs to open and close. Also the reliability of the solenoid to preform as needed for control over engine performance.
Good Answers: 97
02/10/2011 5:04 PM
Why would the solenoids require "high voltage", he asked.......
CRTL-Z
02/10/2011 5:42 PM
I took that to mean "hi-power". Maybe Fredski isn't an electrical type.
02/11/2011 6:04 AM
I thought you had "some real work now". Perhaps that real work was typing another response or performing another Google search - you do seem to love your Google searches, I suppose that is why you are often referred to as the "Google" Engineer. Clearly you are a very very busy and important person. Ha ha ha.
02/11/2011 6:15 AM
Hahaha, anonymous hecklers. Cowards.
02/10/2011 6:10 PM
The exhaust solenoid in particular would have to be actuated with a high voltage because the maximum force produced by a solenoid happens when the current is at its peak. Remember that the current lags the voltage applied to a solenoid and that the movement of the iron core lags the maximum force applied. So with not one but two differential equations each producing a lag, a high voltage must slam through the exhaust solenoid to attempt to open the valve while fighting both the inertia of the valve and the back pressure from the exhaust gasses.
Good Answers: 97
02/11/2011 9:16 AM
Thanks redfred,
So it would require high voltage and current. That would be some switching network.
At what point (frequency) would the coil saturate?
I wonder what the cost would be as opposed to conventional mechanical?
CRTL-Z
02/11/2011 9:30 AM
Actually one can get clever with the drive circuitry by using a non-linear drive electronics that produce high voltage to speed up the transitions but provide the high current at a low voltage. This work has been done to my knowledge with some military engines as part of a research project on variable valve timing applications. There is as usual a maximum speed and force limitation that one reaches with this approach. To find that though one must really know all of the parameters or empirically test for them.
Good Answers: 97
02/11/2011 9:38 AM
Sounds like the coil would have to be biased. Appears complicated.
CRTL-Z
02/11/2011 10:57 AM
No coil biasing is required. But it is complicated. What isn't these days.
02/10/2011 6:06 PM
I miss DAS.
02/10/2011 9:39 PM
I see a few major design hurdles or outright impracticalities with this design.
First off the springs in a engines valve train are surprisingly efficient despite their seat pressures. What force the one side of the cam lobe exerts while compressing them gets returned back to the other side as it closes. To spin a camshaft takes surprisingly little power despite the amount of combined force all the valve springs exert.
Also the high seat pressures are necessary to get the valves to close fast enough at higher engine speeds. Low tension valve springs will allow for a condition called valve float to happen which leads to catastrophic engine damage if not properly controlled.
The next one is the variable compression ratio produced by use of an electric blower system on the intake side of the engine.
Do you have any idea how much power it takes to compress air to multiple ATM levels at the volumes that typical vehicle engines use?
Lastly turbochargers are an efficient way to produce power because they take advantage of what is normally mostly wasted energy being dumped out the exhaust system.
They do not produce much back pressure when spooled up but they do take advantage of using a small pressure drop at a high volume of flow to scavenge usable energy out of the exhaust gases from the expansion and resulting cooling down that occurs in the turbochargers drive side turbine wheel. Or so thats the accepted theory my gearhead buddies explain it with.
02/11/2011 6:38 PM
Thank you for your reply. You might want to re-think your notion that a spring is "returning" power to the engine once it's unsprung. The energy is lost during compression. The valve returns, the energy it took to compress the spring is lost. Your second point about valve float. Valve float is a product of RPM and spring pressure. In order to get higher RPMs the higher you go the higher the seat pressure has to be to keep the cylinder sealed. Because the valves I propose are not following a cam lobe they would never overshoot a lobe or cause a valve to bounce at higher RPM. Higher RPMs could be achieved without robbing the engine of power that is absorbed by current valve springs. Nascar engines typically have seat pressures exceeding 220 lbs. Top fuel, 550 lbs. These are huge power robbers but necessary to seal these engines at higher RPM. Do I have any idea how much air has to be compressed? Was that a rhetorical question? All engines are have limits depending on their displacements. Most 5 litre engines are limited to around 600CFM. The engine size I propose is actually quite a bit smaller. It's very doable. Thank you for enlightening me on how well a turbo works. Did you actually stop to think that this engine could ALSO be turbocharged to take advantage of a turbo and add to it's gains?
Good Answers: 110
02/11/2011 7:26 PM
You are holding a couple misconceptions.
A small amount of energy is lost to lubrication shear, and hysteresis in the spring, but the vast majority is returned. As the valve spring extends it drives the cam (and the cam, of course, drives the crank. You can feel and see this if you disassemble a single cylinder engine.
It is related to rpm and spring pressure but not a product of those two factors. It is the result of inertia, and can be reduced by cam profile engineering (and of course heavier springs).
In desmodromic valve systems, the seat pressure is very low. Once on its seat, the cylinder pressure keeps the valve closed. In ordinary engines, the on-seat force on a valve ranges up to an amount equal to several times the spring force. The reason for stiff springs in high rpm engines is to overcome inertia, to prevent valve float, not to add seat pressure.
How far along is your prototype?
Think big. Drive small.
02/11/2011 7:47 PM
The cam drives the crank....I had no idea.
Good Answers: 110
02/11/2011 11:28 PM
I gathered that. Although this is theoretically obvious, is is less obvious in practice with multi cylinder engines, because one closing valve is acting against an opening one. But in a single (especially an overhead cam single) this becomes obvious when you try to time the cam and install the cam chain: the cam has a strong tendency to rotate away from the lobe. If the timing chain tensioner in such engines is out of adjustment, the chain makes a racket as the tension reverses with every valve cycle.
A disadvantage with many camless valve timing schemes is that this return of spring compression energy is lost. If there is valving involved, a lot of the energy used to accelerate and decelerate the valves goes off as heat from fluid turbulence. In purely electric systems, there are iron losses, etc.
02/11/2011 1:43 AM
"Because the valves are not limited by the geometry of a camshaft engine they can be configured in any orientation to maximize chamber shape. Side by side, 90 degrees, 180 degrees, etc."
Hahahaha, really? so how would valves at 90 or 180 degrees work again? Wow, if we made perfectly square cylinders, we could pack more in a smaller space! Hahaha, very entertaining.
02/11/2011 2:19 AM
Check out www. Coates engine . com
h
02/11/2011 6:56 PM
Totally different concept, but thanks for the reply.
02/11/2011 2:22 AM
Have you done a website for this yet?
02/11/2011 6:02 PM
No I have not.
Good Answers: 25
02/11/2011 3:37 AM
Positive and infinitely variably control of valve timing is a definite plus - I can see only advantages in it, provided of course it can be brought to at least the same level of reliability as the current mechanical and mechanical/hydraulic valve actuation systems.
As for the rest, it makes little sense to me. The work of compressing the charge air has to be done, and I don't see how it is better to do it externally with an electrically driven compressor whose power ultimately comes from the engine crankshaft, through two power conversion steps, at a considerable loss.
02/11/2011 7:02 PM
Thanks for your reply. It isn't "better" to compress outside the combustion chamber. The idea is being able to have variable compression. It also allows for individual cylinder filling. As an engine ages individual cylinders have differences in their compression due to build up of byproducts of combustion, valve and ring wear. The ability to individualize each cylinders filling is huge even if the power to compress is identical to a typical engine.
Even with 100's of thousands of miles of wear this engine would run as smooth as the day it was 1st started.
02/11/2011 4:10 AM
Please deine in more detail what you have stated in sketches.
You appear to be talking through a two-stroke engine.
In thermodynamics terms the very action of the Carnot Cycle is limited in absolute terms by the logic of the system.
Represent your "Invention" if you would by a series of sketches explaining how the enrgy is translated to rotational motion (assuming that is what is intended) or linear motion (if that is the alternative.)
Thankyou.
02/11/2011 8:19 AM
1. The things you propose have or are being experimented with today.
2. You appear to lack some understanding of basic engine design.
3. Why do want to put lipstick on such an old sow as the IC engine? You're adding a lot of complexity when simpler, more efficient solutions are available.
02/11/2011 9:04 AM
Google OPOC.
Good Answers: 114
02/11/2011 9:43 AM
02/11/2011 11:07 AM
Good Answers: 48
02/11/2011 11:33 AM
This has two crankshafts for a single cylinder. The beauty of the APT design is that it has a single crankshaft for two cylinders. It ought to be much cheaper and easier to make. The APT unit seems a bit unwieldy in some ways, but I like the look of it. It always helps, particularly with automotive technology, to have the technical bits explained by someone with a german accent: http://www.engineeringtv.com/video/Opposed-Piston-Opposed-Cylinder
I was surprised to see these. The opposed piston design has been around for a long time, and I remember (very vaguely!) reading up on it in IMechE papers back in 1981. The principle seemed good, but it always seemed to be an unwieldy and impractical design to manufacture.
Good Answers: 114
02/11/2011 12:13 PM
this one is pretty fun
3 cranks for 3 cylinders, maybe have the transmission inside delta
any valves would be rotary & not under any great pressure
Good Answers: 48
02/11/2011 4:55 PM
Napier, now that's a blast from the past (pun intended). Quite tidy in a way, you could possibly put all the ancilliaries, as well as the transmission, between the cylinders. Opposing piston designs were always a better idea for diesels, getting the compression ratio with a much shorter stroke. It's a shame that this could be all forgotten within a couple of decades, whilst our kids point with incredulity at the mechanical abominations we wrinklies adored.
02/11/2011 12:30 PM
Thanks for sharing! Both sights were interesting!
02/11/2011 12:27 PM
The Italians got around the usual valve train with heavy return springs, on one of it's motorbikes, the valves are returned by the rocker arm as well as opend by it, it is called a Desmodromic valve drive, and is used on some of the Ducati's!
Xanasax
Good Answers: 48
02/11/2011 5:08 PM
Ducati have been using desmodromic valves for 40 years or more. They are OHC so there is no rocker, the camshaft lobes coming between the upper and lower actuating arms that open and close the valve. The purpose was to eliminate valve bounce at high engine speeds. I was always surprised that no one else really went for desmodromic valves, so I can only assume there must be some disadvantages or complications. But then the performance of Ducati bikes over the last 40-50 years speaks for itself ( not to mention the absolutely gorgeous sound that emanates from them).
Good Answers: 110
02/11/2011 1:47 PM
That's quite a few ideas strung together, but in theory such an engine would work. Many manufacturers are working on electrohydraulic valve actuation for roughly the reasons you mention: complete freedom in valve timing, under electronic control. As you can imagine, getting the accelerations and decelerations right (so the seats don't get too badly pounded) can be tricky.
Engines with compression external to the combustion chamber are not uncommon (in labs and patents) but none have made it to market. Flow losses can kill the concept. Adding in the losses of an electrical system doing the mechanical work would further erode efficiency. (You'd have a very large generator on the crankshaft and a very large DC motor doing the compression work, for a combined efficiency of about 80%, at best. A direct mechanical link (as in crankshaft to piston) is nearly 100% efficient.
But it would be fun to build one, and see how it goes. This sort of thing can be modeled given enough computer time, and that would be a good pace to start.
02/11/2011 6:54 PM
Thank you for your reply. I wont argue with you over the efficiency but I think you're missing a few points. Variable compression going both ways (up or down on demand) can't be achieved with a turbo or supercharged engine. The design I suggest would make an engine that self adjusted to any condition. No fixed compression engine can do this. The engine would have any emission profile that was programmed in it's engine management system. And unlike any current design because the cylinders filling pressure is measured on every filling cycle the engine would outlast the car and run perfectly. As one or more cylinders began to lag (from ring or valve leakage) they would be individually compensated. The engine would run smoothly without a noticeable loss in power year after year. I agree it would be QUITE fun to build one.
02/11/2011 7:07 PM
Hold on a minute there.
There are several things that I like about what you are proposing to do with this theoretical motor design but to claim any kind of improved longevity or subtle performance characteristics before you built one has quickly put you in the bogus snake oil salesman category. Until you've fabricated at least a testable mock-up you cannot claim any results. This is because you do not have any results, only fantasies.
02/11/2011 7:11 PM
"I believe" the things I cite would happen, better?
02/11/2011 11:24 PM
Better but much too late to help and hardly sincere. An unsolicited mea culpa might have helped.
Good Answers: 110
02/11/2011 11:10 PM
Actually, in practice, this is achieved with modern turbo systems. Cylinder pressures immediately prior to ignition (on the compression stroke) can range from about 1 atmosphere to many atmospheres (from well under the expected pressure from the geometric ratio to well over the expected pressure from the geometric ratio) Many modern, turbo spark-ignition engines now have perfectly flat torque curves (from 1500rpm to 4500rpm or so) as a result of electronic control. The torque produced is not inherently limited by the airflow but instead by engine structure and heat tolerance, so the controller limits peak cylinder pressures to safe values.
Measuring filling pressure is a round about way to prevent detonation. All turbo engines and virtually all car engines do continuous incipient knock sensing and continuously modify timing and turbo boost to prevent destructive detonation. Filling pressure is measured indirectly, but quite precisely, by mass air flow sensing. By measuring manifold absolute pressure, air temperature, and rpm the ECU can calculate the right ignition timing and injection amount (and can get quite close even without closed-loop O2 feedback). The ECU already "knows" how full the cylinder is, without having to measure actual cylinder pressures.
It is interesting to note that in spark ignition engines, turbos are no more efficient than normally-aspirated engines in brake specific fuel consumption terms. They can produce more power per unit of engine weight, but even there, the advantage is not compelling: thus we have a mixture of turbos and normally-aspirated engines in the high performance car world. Making an engine bigger remains the cheap route to more power. (The situation is different in diesels, where turbos can increase fuel efficiency.)
The correct compensation for a cylinder lagging because of valve leakage is to shut the cylinder down, rather than trying to keep filling pressure up. Valve damage quickly escalates from blow by, putting the whole engine at risk. Shutting the cylinder down would prevent damage but would not make the engine run smoothly. (This is another case where the spring effect comes into play: shut down cylinders are more efficient with the valves closed, so the piston/cylinder acts as an air spring, with much of the compression energy returned when the piston goes over TDC.)
Fully-variable electronic valve actuation (generally electrohydraulic to produce the necessary response times) has been in the works for many years. So far, the only near-production versions have been on large, low rpm engines. It's a good concept that has been challenging to implement. The size of valve springs shows how difficult this can be: even with a cam profile that very smoothly accelerates and decelerates the valve, still hundreds of lbs of force (more or less, depending on engine size and speed) is required to prevent over shoot. (See the Ricardo paper linked below: at 6000 rpm the force goes to about 4000N -- 900 lb -- in a Ford Ranger 4 cylinder engine.) Producing a miniature actuator that produces such high forces and that can be cycled 100 times per second, while controlling accelerations and decelerations is no small challenge for even a Toyota or a GM. The interest in the concept started in the 1980s, and still we don't see it in engines.
Electric supercharging has been around for a while, so you could buy a production unit to experiment with. The valve actuation, however would be quite a project -- one that would be done best by teaming up with one of the companies that have already made some headway: Ricardo for example.
When you build it and find that it works well, stop back so all of we naysayers can take credit for it.
Good Answers: 74
02/11/2011 11:32 PM
GA. Nice pdf.
The Twain Has Met
02/11/2011 2:08 PM
butterfly valve or one directional velve http://www.google.is/images?hl=is&biw=1280&bih=899&q=Check+valve&um=1&ie=UTF-8&source=univ&ei=9ohVTZWuJ9CwhAeawejEDA&sa=X&oi=image_result_group&ct=title&resnum=2&ved=0CD8QsAQwAQ
guds777
02/11/2011 2:19 PM
Dude,
What have you been smoking!!!!!!
02/11/2011 3:04 PM
yours moms weed.
guds777
Good Answers: 114
02/11/2011 3:44 PM
or the more traditional
for a 2 stroke reed valve
02/11/2011 3:58 PM
Insacly, i was only bringing up a concept, so you dont need to use cams, springs and velves, better to use a one way valve. no loss of power there.
guds777
02/11/2011 3:06 PM
Try a Rotary engine. I had one in my RX-7. No valves or springs or camshaft.
Ron
I went to Texas A&M, I am proud to be an Aggee. Proud to be an Aggey, Proud to be an Agie.............Proud to have gone to Texas A&M.
Good Answers: 48
02/11/2011 5:18 PM
The gains from eliminating valves, springs & camshafts are negated many times over by the inherent inefficiency due mostly to difficulties in sealing the rotary piston. I have always been a huge fan of the rotary (or Wankel) engine, for many reasons, if only the sealing problem could be resolved. The best application I've seen for these engines is in drones or microlights, because the power to weight ratio is exceptional.
02/11/2011 5:10 PM
I am control systems electrical engineer but can see a possible limitation in the speed of actuation of the valves electrically. They would have the same operational time at any engine speed which would limit high engine speeds unless a sophisticated 'advance' system was used to compensate. Not impossible but detracts from the simplicity.
Penttijp
02/11/2011 6:40 PM
I'm sure you're familiar with anticipation circuits and their function.
02/11/2011 7:27 PM
Fredski,
Got your PM. Thanks a bunch.
Unfortunately, so far all you have offered is a single narrative extolling the virtues of your unproven, untried, unverified theory/theories.
There are significant energy conversion losses you do not account for.
If you are offended by my comments, take a number.
I'll start the OT voting with 5.
02/11/2011 7:53 PM
I'm not offended. Here's a quote that I think applies to you and I. I'll let you decide who you think is whom.
Talent hits a target no one else can hit; Genius hits a target no one else can see. Arthur Schopenhauer
02/11/2011 8:09 PM
Fredski,
I claim neither talent nor genius.
I salute your genius. I could never have conceived of the ideas you have presented here.
Perhaps, that's why I need proof.
Good Answers: 114
02/11/2011 8:43 PM
My My aren't you presumptuous
everyone see's the target
I can't see as you have done much but a bit of conjecture about some possibilities
You have shown a significant lack of understanding of most of the basic concepts involved, which has made for some entertainment
I wouldn't spend that 1st million quite yet
02/11/2011 8:05 PM
One common misconception is the compression ratio issue. Actually the applicable term would be displacement ratio. Only naturally aspirated Diesel engines could be considered to have a fixed compression ratio.
The reason I am referring to it as a displacement ratio is because in a spark ignition engine the throttle varies the incoming flow and thusly the manifold pressure. At idle there is a high manifold vacuum that represents a very low pressure going into filling the cylinders. When that low pressure is compressed by the compression stroke the final compression value can can be lower than 1 ATM at TDC of the compression stroke during idle.
What that means is that a spark ignition engine can run just fine with a displacement ratio of 20:1 with no problems right up until the intake pressure level allows for the peak compression stroke pressures to go high enough to produce spontaneous combustion of the fuel. That is what causes low octane rated fuels to ping and knock in high compression engines but only when the throttle is open more.
02/11/2011 8:46 PM
The work done by compressing a valve spring is returned when the spring expands.
Friction losses are small and can be reduced with roller bearing.
Plane bearings are good for 300,000 miles - roller bearings last 50,000.
"Elimination of massive spring pressures that must be overcome constantly greatly enhance efficiency" = FALSE
02/11/2011 9:34 PM
http://www.grandprix.com/ft/ftpw012.html
guds777
02/13/2011 1:21 PM
Hello, this is my first post on cr4. I'm not an engineer just a lowly beginning physics student, but I do know quite a bit about cars and engines.
I may be wrong but it appears Fredski wishes to make quite a few radical changes to the performance profile of a basic IC reciprocating engine through nothing more than a change in the valve train and (possibly?) the associated intake/exhaust efficiency improvements? In so far as automotive technology, I believe that particular hurdle has been fairly successfully vaulted with some rather elegantly simple electro-hydraulic systems through various manufacturers. In fact, it is my understanding, that several existing systems have such a high degree of variability that the throttle butterflies are effectively redundant. This is why we have the extraordinary flexibility available in some of the new engines (30 mpg driveable, petrol V6 that will still deliver 300 hp (NOT at 30 mpg) when needed).
Most of the new developments in car engines seem to focus on combustion chamber refinements, heat control, intake/exhaust systems, and fuel delivery/injection systems. Making the valves open and close doesn't seem to be even on the radar. Nor does it seem to be at such a level of inefficiency as to currently effect to any significance the performance capabilities of a given power plant. The current generation of variable valve lift and duration valve trains are very reliable and seem capable of flowing air/fuel and exhaust gasses at any desired fraction of a given cylinder head's wide open flow capabilities.
The performance limitations are instead a product of structural limitations, heat, durability/reliability specs, etc.... There are some 300 hp engines that won't produce 600 hp not because they can't take in enough fuel/air mixture and efficiently burn it, but because they will break.
As far as the title of the thread, if I'm correct as to your stated proposition, I don't think solenoid actuated valves are an effective solution. I do think they were an excellent idea when they were first introduced many years ago, and possibly helped to inspire some of the modern variable valve train systems available today. Spherical valves also looked neat, no reciprocating mass, yay!
Anyhoo, if you wish to tackle the inefficiency of the IC engine, I suppose you might want to look at an efficient way to use the waste heat of the engine to accomplish something other than looking pretty in infrared.
02/13/2011 1:32 PM
Hi Auntie,
Welcome to CR4. It's refreshing to have a student contributing, instead of asking us to do their homework for them. Although, there are some very intelligent folks here who can, and will, help students figure things out, without doing the work for them.
I agree with what you say.
Cheers.
02/13/2011 1:48 PM
Thanks for your reply. If you read all the replies you might have gotten some further advantages that I didn't state on the initial post. I also think you missed the big picture. I never stated that variable valve timing isn't good or that my method is better. The entire idea of the valves is that they can adjust their duration to provide for individual cylinder filling. No current system comes close. If there was an operating system such as I suggest then cylinder filling could be tailored to each individual cylinder even as the engine wears. So as 1 or more cylinders begin to wear (valve seats, top compression ring, etc) these cylinders would be a drag on the entire engine. You say you know a lot about engines. I assume you've performed compression tests. If you have a V-8 and just 1 cylinder is a few % less than the rest that cylinder causes a loss of power and more vibration. It harms crank momentum, etc. Mine would have even filling under all conditions regardless of the age of the engine. No other design even addresses this.
"Fredski wishes to make quite a few radical changes to the performance profile of a basic IC reciprocating engine through nothing more than a change in the valve train" Really? you must know of a variable compressor that provides compression externally. Care to share? BTW, adding a turbo just adds to my design.
02/15/2011 8:53 AM
Welcome to the forum.
J B
02/13/2011 6:38 PM
So...I don't think I missed the big picture. I am doubtful that your stated goals from this design can be accomplished through the means you have described.
With your description of the charge portion of the "everything but power" cycle. You have an external electrically powered compressor (and probably a storage tank) at the ready to deliver the compression charge of air during the last 1/4 (and effectively, 100 percent) of the compression stroke. So, lets say a 300cc cylinder running at the low end 6 to 1 compression and loping along at 800rpm.
This compressor/tank arrangement has to deliver 300cc of air at approximately 90psi (6atm) in the time it takes the electric valve to open and the piston to complete the last 1/4 of its compression stroke. So in 0.0125sec, minus the time the solenoid cycles, this electric compressor system provides 300cc at 90 psi 800 times a minute at idle for one cylinder. 68 cfm at 90 psi for a v8 at idle
The compressor is being driven off the car's electrical system, the solenoids are also being driven off the electrical system. On a v8 these solenoids are firing twice each for every revolution of the crank or one solenoid firing every 0.005 sec for a minimum of 0.0125 sec. And this is just the intake solenoids.
The compressor alone will require around 10-12 horsepower (Over 500 amp draw at 13.2 volts!) to maintain the flow and pressure required to maintain idle, and that is not including the mechanical-electrical-mechanical transit losses in your proposed compressor system. And the resulting air charge to the cylinder will be a "hot" charge.
The solenoids, if there are 16 and drew a hypothetical 10 amps each at 13.2 volts (this feels low btw) would take another couple horses. And since they are either full open or closed, duration variable only, a throttle must still be used, retaining the basic pumping losses inherent in most reciprocating designs.
As far as the idea of individually compensating for a degrading cylinder. K Fry said it already, if the cylinder is that bad, shut it down. A weak cylinder , normally naturally regulating through its decreasing ability to draw in and compress a given charge, if artificially maintained through an individual cylinder management system, to maintain cylinder filling. Will result in increased blow by of combustion gasses resulting in lubricant contamination and further harm to the rest of the machine. Large industrial engines have individual cylinder management and electric valve actuation (Also mentioned by K Fry) but they also run at low rpms and are quite large. These engines generally shut down a weak cylinder and can be overhauled one cylinder at a time.
That vibration you mentioned from imbalanced power pulses in an engine with a weak cylinder means something is breaking or broken and needs help. If your system were able to compensate, making the engine run smoothly year after year. It would do nothing about the worn or leaking cylinder rings which would continue to wear and leak, nor could it really do anything about leaking valve seats, guides or seals as the system is just open or closed. I am pretty certain at the end of those years, the engine would not be running nearly as efficiently as it was smooth. The filling of the cylinder is irrelevant if the mechanical components are unable to contain the compression gasses.
In conclusion, I would not add a turbo to this design.
In reply to #64
02/13/2011 6:49 PM
Just curious. Why have you spent so much time looking for everything wrong you can cite? If I don't believe in something I just pass and don't waste my time. I really don't get the highly negative blogger energy here. I doubt for a nanosecond you tried to actually consider why this WOULD work. All your efforts seem to be search for what you believe what wont work. You're clearly intelligent. Why the negativity?
BTW, I never said it was an 8 cylinder. I was thinking 4.
Good Answers: 74
In reply to #65
02/13/2011 6:54 PM
Devils advocate=priceless
The Twain Has Met
In reply to #65
02/13/2011 6:57 PM
Don't whine, prove your concepts.
Your job is to prove that it can work. Our job is to keep you honest.
If you want cheerleaders, hire them.
Negativity, skepticism, cynicism go with the territory.
If it was a stupid idea there wouldn't be any responses.
Your turn.
In reply to #68
02/14/2011 10:36 AM
You're a really condescending dude with a superiority complex. I don't have any job to perform on this blog because you tell me I do. You're laughable and annoying at the same time. Whenever you introduce anything new there will always be your kind there. And you're right, it does come with the territory. That doesn't mean I have to even acknowledge it. If this blog had an ignore feature you'd be my 1st guest. You're delusional thinking you have a "job here to keep me honest". You're just some clown who has been sitting at a computer for years responding to blogs as if you're in charge. Dude wake up, you have over 8 THOUSAND posts. If you posted once a day it would take over 23 years to amass that many posts! You've spent too much of your life in the cyber world. If you've decided your station in life is to sit at a computer screen all day, day after day ranting on blogs about your self serving opinions then please go right ahead. Fortunately there are a handful of people like Auntie that will bounce a few ideas back and forth. All I expected was discussion. I'm not here to earn points with people who spend their lives on this or any other blog as if it's some club I need to earn my way into.You've offered nothing to the discussion of any use. IE, you're useless to me. Please go away from my thread. You might actually want to turn the computer off for a while and venture out into the real world, do you remember that place?
In reply to #77
02/14/2011 10:46 AM
A bit sensitive, aren't we?
Your time would have been better served defending your unsubstantiated opinions, instead of trashing me.
Cheers!
In reply to #77
02/14/2011 1:55 PM
So what does a persons post count have to do with anything? 8500+ posts over a three year time frame is around 23 - 24 a day. Thats not much considering that any active contributor to a active thread can easily put 5 - 10 posts in to it in one day. Spread that 24 posts over a half dozen threads or more and thats not much really.
Apparently you are not aware that people who hang around one engineering sites tend to be more experienced and knowledgeable about engineering related topics than the average person from off the street. It just goes with our career and personal interest choices we each made in our lives.
If you want to brag up your concept to a bunch of doe eyed clueless half wits who will hang on your very word take your idea to the over unity or environutter/para science AE sites. Most of them couldn't engineer their way out of a cardboard box by themselves so they should eat up your new design like its the holy grail of para science environutterdom.
I am not saying your design is an impossibility or a true para science type creation but rather that some of us here do have considerable first hand knowledge and experience with many of the concepts and components that you have suggested here. Regardless of where you use a camshaft and a spring to open and close a valve it still follows the same basic rules of physics and conservation of energy.
Same with compressing a gas. Regardless of how you do it it takes a specific amount of energy that has to come from someplace in order to do the work. Some methods are more efficient than others and some are better suited to exploiting what could be normally viewed as waisted energy but still energy is energy and it has to come from someplace.
In reply to #79
02/14/2011 3:14 PM
Thanks for your post. Your assumptions about what I'm aware of are off target. Some of your pals on here might in fact be knowledgeable on a host of topics. Treating someone new like a piñata is just rude and unnecessary. The highly condescending tone of some of these jokers might be tolerated by some people, not I. Would you talk down to a colleague in business? You wouldn't last with that conduct. Some of these people spend so much time on blogs they self anoint themselves as in charge. Not only is that completely hollow it's pathetic. If someone wants a healthy discussion I'm all for it. If they think I have to kiss their ring to get them to comment they can just skip my posts.
In reply to #80
02/14/2011 3:54 PM
You should hook up with M S DIVEKAR. He too likes "healthy discussions" on novel engine concepts.
In reply to #81
02/15/2011 9:34 AM
In reply to #80
02/14/2011 6:23 PM
I support new concepts or new variants of concepts far more than most and I too have been through the trial by fire experience of bringing a new concept on a subject into public view.
Around 2009 I made my early designs for a thing called a Grid Tie Inverter open to the public on another forum that deals with electronics. At first I was not received well and took I a lot more poking than I cared for and found the saying of 'Put out or get out' is very true when dealing with new concepts. I put out the designs, the technical write ups describing those designs, the pictures of the basic GTI units built on those designs, and stood my ground like a professional. So if you are curious as to where I stand now on that subject just do a general search for grid tie inverter trust me if you go looking for designs or schematics for them you will find me!
What this means is that you can boast theory and concept about your invention all you want but if you want to be taken serious by the people who work with anything remotely similar to what you propose then you have to put out the real information in its entirety or get used to being hassled for being a crackpot who isn't knowledgeable of the reality of what his proposes.
In reply to #82
02/14/2011 7:38 PM
Are you the guy in the youtube vids?
In reply to #83
02/14/2011 8:29 PM
Not that I am aware of. What Utube videos?
In reply to #87
02/15/2011 8:45 AM
I Googled it and saw a few vids on grid ties. Inverters and charge controllers have been around awhile. What unique approach were you working on?
In reply to #80
02/14/2011 7:42 PM
You must be new to Internet forum discussions. Honestly, if you feel this discussion has been "rude", then I strongly recommend you disconnect your Internet service and stick with face-to-face conversations.
In reply to #84
02/14/2011 7:48 PM
Okay I'll do that right now. I should have never expected an intellectual exchange.
In reply to #85
02/14/2011 7:49 PM
That's because you haven't furnished anything even remotely intellectual. Good riddance.
#88
In reply to #86
02/14/2011 9:24 PM
They always promise to never darken our door steps again, but keep coming back :D :D
Son of Editor Crankshaft
In reply to #65
02/13/2011 7:04 PM
Auntie was at least talking about ideas. If his ideas challenge your ideas, you are free to respond (still within the realm of ideas), and give facts/figures/calculatons/verified observations/etc. Instead, you have abandoned the realm of ideas and have dabbled in alleged personal characteristics. Have you been taking lessons from kastrupsky?
In reply to #65
02/13/2011 7:14 PM
The turbo comment was admittedly a little swipe. But you are wrong about me considering whether your idea might work.
After reading your response I went back and carefully went through your descriptions and drew little diagrams to better understand your proposal. And while I am always happy to see someone thinking outside the box (I think that is a good way to be), I did see several practical concerns that should be considered before trying to build the thing.
I have built lots of things that didn't work, that's part of the fun, but it can save some time and energy if some obvious issues are brought to your attention earlier rather than later in your idea's development.
I think it's awesome that you are thinking about solutions to problems, I just think you may have misidentified what the real problems in the IC engine are.
In reply to #70
02/13/2011 7:22 PM
Okay, can you tell me how you arrived at your PSI figure? Top Fuel dragsters run 500 inch engines with blower pressure around 60 PSI. The engine I envision is in the 1 liter area. Maybe 50-70 inches. Your figure seems incredibly high.
In reply to #71
02/13/2011 7:38 PM
A top fuel dragster's blower is pressurizing a plenum that feeds the cylinder during its intake stroke, the engine then mechanically compresses that charge during the compression stroke.
Your system has no intake stroke and the entirety of the charged intake air is introduced towards the end of your engine's "everything but power" stroke. This implies it must be mostly compressed when it is introduced to the combustion chamber.
A typical engine that displaced 300cc's and had a compression ratio of 6:1 would have a pre-combustion pressure of around 90 psi (6 x 14.2ish psi) at the top of the compression stroke. Since your design uses an external compressor to provide that charge, it would need to provide an equivalent volume of gas at an equivalent pressure to properly fill the cylinder and get an equivalent charge.
In reply to #72
02/13/2011 7:44 PM
NP, run it as a 4 stroke. It still has all the variables of duration and final comp ratios. I have to get moving. If you respond I'll get back tomorrow. Cheers
In reply to #71
02/13/2011 7:38 PM
Yes and have you ever looked closely at just how big that blower drive belt is and yet they still rip them apart fairly often?
I would say Aunties numbers where on the more conservative side of realistic.
What do you pan to power with a 1 liter engine? My riding lawn mower is packing more than that.
In reply to #70
02/13/2011 9:55 PM
Welcome to the mad house, Auntie.
I agree with both your analysis of this innovative engine concept and that thinking out of the box ideas should not be discouraged but be forewarned about possible difficulties before implementation. You've earned a couple of GAs here.
In reply to #65
02/13/2011 10:15 PM
Auntie has invested so much time on your approach because your motor design is innovative. But just because a new system is innovative does not mean that it has to be successful. You came here to obtain some incite from people with an engineering experience and drive. Listen to the criticisms and concerns of people who have worked in the realm you wish to pursue. Every innovative design initially failed. Knowing how and why it failed allows for new growth in the field to flourish. Rarely does the original idea itself show so much promise that surmounting the initial unexpected complications ultimately reveal a completely new design approach. More often though a careful analysis of how and why the initial design fails reveals hidden truths about how things work.
I wish you the best in your engineering endeavors, Fredski. Remember, careful scrutiny is a hallmark of interest.
Hobbies - Fishing -
In reply to #76
02/16/2011 9:19 PM
Insight or incite? Maybe he was trying to incite....
“Sometimes I wonder whether the world is being run by smart people who are putting us on or by imbeciles who really mean it.” -Mark Twain
In reply to #93
02/17/2011 12:02 AM
Did I do that?
Good Answers: 74
In reply to #64
02/13/2011 6:52 PM
Welcome to CR4.
Well written and it all makes sense. You might be a good guy to talk to about something I have been working on since years. No rush but it will happen one day. Its a pity your so far away.
Have a couple on me, Ky.
The Twain Has Met
#92
02/15/2011 6:57 PM
OOPS! Sorry, I was looking for the talking pinata site. Toodles
SmithW6079
Good Answers: 44
#95
02/19/2011 1:34 AM
How about a single or double cylinder, valveless port induction/exhaust engine. Everything you mention sounds a lot like a Wankel, or rotary type engine. Get rid of the valves entirely, go pure electronic injection, etc.
In reply to #95
02/19/2011 2:09 AM
No Valves! You're a genius. That really simplifies things. Hell, just use a solid block of steel. Think of it, no moving parts. Wow, I'm a genius!
Good Answers: 114
#97
In reply to #96
02/19/2011 2:26 AM
Green anodized aluminium
light weight, green & no valves
Where's my Nobel Prize...
You are an inspiration to me today :D
In reply to #97
02/19/2011 3:01 AM
Green! I love it. You are also a marketing genius!
In reply to #98
02/20/2011 2:54 PM
Perfect! Such a device could be shown to be essentially 100% efficient. The energy used to heat it up would all be returned as it cools down!
Si hoc signum legere potes, operis boni in rebus Latinis alacribus et fructuosis potiri potes!
In reply to #99
02/20/2011 3:56 PM
That's about as close to over-unity as it gets!
Register to Reply 100 comments
AJREPAIR (2); Anonymous Poster (5); Auntie (4); CrimeCrusher (1); cuba_pete (1); Doorman (1); EthicalEngineerPH (1); Fredski (18); Garthh (5); guds777 (4); Holzfeller (4); JBTardis (1); K_Fry (4); ky (3); lighthasmass (1); lyn (10); MoronicBumble (1); ozzb (1); pantaz (1); penttijp (1); piolenc (1); rcapper (5); redfred (8); ronclarke (1); SmithW6079 (1); tcmtech (7); Tornado (4); Unredundant (3); xanasax (1)
