Previous in Forum: Aluminum Sulfate Solution Precipitate Problem   Next in Forum: Reuse of Leather Shavings
27 comments
Good Answers: 146
Machining Graphite
02/12/2011 7:55 PM
I'm working on a project that requires making some refractory mandrels. Graphite appears to be the less expensive choice with the desired qualities, but I know it is brittle and would much appreciate your comments based on experience about shaping graphite with tools.
All I know is, carbide is recommended, and brittleness may be an issue. Any comment on best dremel speed etc?
incus opella
Re: Machining graphite
02/12/2011 8:38 PM
A custom-sized pencil sharpener?
(Sorry, couldn't resist....)
I don't know if metals are out of the picture, but maybe the same technology for making tungsten GTAW electrodes might offer some potential.
Good Answers: 146
02/12/2011 8:53 PM
ha ha, thanks for the vote of miniaturism. (Don't forget Ed Weldon's trick of using a drill as a mini-lathe)
anyway the stocks I am looking at are called "fine extruded" rod or "isomolded" sheet. Just thought somebody who has worked em might give me a few tips.
I know carbide tools are recommended. But that's all I'm getting from google.
incus opella
02/14/2011 9:24 AM
On "Myth busters" they made rocket nozzels from graphite rod using a lathe and what looked like off the shelf tooling.
oilcan13
02/13/2011 12:39 AM
Googling "graphite rods" gives lots of stuff on fishing poles, but "graphite rod stock" might help:
http://www.google.com/search?sourceid=ie7&q=graphite+rod+stock&rls=com.microsoft:en-us:IE-SearchBox&ie=UTF-8&oe=UTF-8&rlz=1I7ACEW_enUS408US408
Good Answers: 146
02/13/2011 6:54 AM
Well, you were right that the search terms weren't quite right... this morning I tried "carving graphite" instead, and found lots of info from people who use it for glass molds.
apparently it's as easy as sharpening a pencil... but a filthy mess. Wet saw recommended.
incus opella
Good Answers: 130
02/13/2011 1:02 AM
I think you need to disclose the "desired qualities" as I have no idea as to the goals in this.
E.g. is this a 'consumable', or electrode support, or 1 of 20 possible reasons for machining graphite, say as in spark erosion?
Or does "Dremel" mean maybe we are in casting? If so, of what?
All would effect the advice applicable, as the graphite employed is different.
Good Answers: 146
02/13/2011 6:28 AM
This is for silversmithing. So the dremel part, I'm thinking of carving out some shallow relief on a piece of graphite sheet.
The graphite stock I was looking at is used for crucibles, mandrels etc.
incus opella
Good Answers: 145
02/13/2011 9:03 AM
I was about to suggest looking at http://www.zircarceramics.com/ and their moldable and castable refractory products. But, if you are casting fine scale silver then their material might not be appropriate.
If you don't mind posting it, who is the manufacturer of the graphite stock that you are considering using?
Thanks,
Bruce
Good Answers: 146
02/13/2011 11:53 AM
Thanks for the link, Bruce. As a matter of fact, I have been looking into the high temp ceramics as well. Interesting product at Aremco. They make these Pyro Paint refractory coatings as well as a potting compound that looks promising for fine detail molds, Ceramacast 575N.
I am considering a possible supplier of the graphite stock; http://www.weaverind.com/ recommended by glass artists for their custom graphite machining.
incus opella
02/14/2011 9:46 AM
Be sure to have adequate exhaust/ventikation unless you really LIKE having black lung disease.
Good Answers: 119
02/14/2011 3:01 PM
I don't have time to read all the input here but I've got lots of experience machining graphite for EDM electrodes.
For hand carving with a dremel I would recommend high rpm and very slow passes with a high speed steel spherical burr mill/cutter of the largest radius you can manage. The burr cutter flutes should have a very flat cutting edge; ie, you don't want a tightly curled flute radius that would tend to grab and pull the tooll into the work. The burr mill will allow the dust to clear the work, especially if you are using a vacuum to clear the crud and provide dust control. Try to keep the area free of the dust as much as possible.
I used to mill flat graphite with a fly cutter at high speed, and turn diameters with the same tool. The tool bit (in both cases) had a large radius, no rake, and a very shallow relief. Drilling is done with a bit that has the cutting edge ground back severely with a face nearly perpendicular to the material. The idea is to "scrape" rather than "cut".
I hope you have a very steady hand. Any inadvertent gouging will likely chip and/or fracture the graphite. Slow and steady is the methodology.
Hopes this helps.
Hooker
Re: Machining Graphite
02/13/2011 11:24 AM
I cannot offer direct help here but I do remember one of our machinists at work shaping a large block of graphite (many inches) on a lathe for some experiment. I remember that the block was turning fairly slowly (~30rpm). He was marking a cutting line with a white pen at the time. (When I see unusual things at work I like to find out what's going on. These guys normally fabricate things out of metals and the occasional block of silicon.) He said that with how brittle graphite was he had to take only small parts off at each cut. He also said that he was grateful that graphite was relatively cheap as he pointed to a small pile of broken blocks. When I left the room I heard the lathe speed up followed by a simultaneous crunch and expletive. The next day I saw the machinist and asked him how that project was doing. He said that he finished and the requested three machined pieces of graphite were done but it sure made a mess of the shop.
Good luck.
Good Answers: 146
02/13/2011 12:09 PM
GA. I didn't find any useful comments about brittleness in my research this morning, but the mess is something everyone agrees on.
In fact, check out the cautionary tales and advice at the bottom of this page. It's one thing to make a mess, another story to put your machinery in jeopardy because of the dust.
I've pretty well decided at this point, to get a few simple mandrels machined for me, and get a small graphite sheet to try out as a work surface (graphite, carbon, charcoal make it easy to reach working temperatures, cw firebrick and other surfaces that absorb heat). As for the mold carving idea, it looks like graphite is not the best choice...
incus opella
02/13/2011 12:31 PM
Come to think of it, since that graphite machining day the ancient hand me down lathe and milling machine that were in the room have been replaced with much newer machinery. The only two machines still in place from that day are a grinder and band saw that were on the other side of the room. Maybe that's just a coincidence, maybe the graphite dust did those machine in, or maybe the dust damage is why they accepted the graphite milling job on the old machines in the first place.
Good Answers: 130
02/13/2011 4:24 PM
If it's a lathe job, you really need a very vibration free tool post grinder - not a normal cutting tip.
To Artsmith;
Why not use a wax positive and plaster?
Good Answers: 146
02/13/2011 4:42 PM
why not wax and plaster:
The original plan called for refractory mandrels, not molds. The mandrels are to support work for fusion. I started thinking about molds after reading about the refractory ceramics, and then comparing graphite costs/properties and wondering if a piece of graphite could be carved.... etc.
off on a tangent, but if I am spending on new tools/materials I want to know everything that is feasible to do with em....
incus opella
Good Answers: 130
02/13/2011 4:55 PM
Ah - I see - given asbestos is naughty
It might be worth your while to look a ceramic beads, perhaps cylinders, you can thread onto a rod. They are quite hard, but diamond tips/discs and water cooling will let you carve them. Dry them in your kiln thoroughly after cutting.
Good Answers: 94
02/14/2011 5:38 AM
The mess is not just during machining. We had some jigs made from graphite once but gave up using them because of the mess just from handling them.
Good Answers: 146
02/14/2011 6:40 AM
Thanks for the heads up.. I will make sure to discuss this with the machinist. I have a graphite stirring rod and there's no dust from handling it at all. It's a very hard stock and, obviously, whatever dustiness is generated in manufacture they get rid of it so the product is dust free. That's what I'll be asking for, for sure!
incus opella
United States - Member - US Navy Veteran
Location: Nothing sucks more than that moment during an argument when you realize you're wrong.
Good Answers: 22
02/13/2011 11:51 PM
Here's some numbers to chew on and remember DO NOT inhale the dust!
Machining graphite electrodes effectively demands a fast spindle, a fast control . . . and dust collection. Requirements like these make it easy to see why graphite electrode milling is one of the few jobs that has machining centers designed specifically for it.
Micropulse's graphite machining center was supplied by Bostomatic (formerly Boston Digital; Milford, Massachusetts). The machine features a 30,000 rpm spindle and a CNC-based compensation system that maintains accuracy by adjusting for thermal effects.
Typical programmed parameters for finish milling used to be 3,500 rpm and 30 ipm. Finish cuts now are run at 35,000 rpm and 400 ipm.
on the older machines, the difference between choosing a step-over of 0.005 inch and one of 0.003 inch
You never know when it will strike, but there comes a moment when you know that you just aren't going to do anything productive for the rest of the day.
Good Answers: 151
02/14/2011 9:02 AM
Graphite is easily machined using conventional tools, milling, turning, or grinding. It is brittle and tends to be chippy, so some care is needed. Always cut into the work rather than cutting off to an edge. It is also rather abrasive so grade C3 carbide is recommended if you are going to do a lot of cutting. Graphite grinds very well with a vitrified alumina wheel. But it is dirty, a good dust collector or vacuum cleaner is an absolute necessity. The most important factor is to use a good grade of graphite. I recommend an EDM grade such as Poco EDM 3
02/14/2011 9:04 AM
I used to machine graphite all the time for our EDM machine. It is easy machining and you can use coolant on it with no ill effect to keep the dust down. There are many different grades as well. I was more familiar with copper impregnated graphite. CNC machining will obviously be your best bet for fine intricate details but it can be successfully done on manual machines as well. If you use a Dremel, you won't want to use coolant so use a vacuum with a fine dust filter.
Good Answers: 146
02/14/2011 11:16 AM
It's an interesting point that the degree of difficulty and brittleness may depend on the grade of the graphite. The dust issues seem to apply to all.
Sadly dust management is not my strong point. Since I don't have a good vacuum setup, it looks like I won't get to play with the graphite this time around. Rats!
incus opella
02/17/2011 3:17 AM
Try looking in the "Machinist Handbook" There may be a table for cutting graphite, also tooling manufactures like Valenite and Kenametal have free engineering help available on the web and by phone.
Good Answers: 181
02/20/2011 8:37 AM
Contact Morganite, they will do mall batch specials.
04/28/2012 2:11 AM
CR4 ADMIN: Deleted Post
Spam: This post was deleted because it contained advertising outside the Commercial Space forum. Please review Section 14 of the CR4 Site FAQ about advertising.
Register to Reply 27 comments
34point5 (3); Anonymous Poster (2); artsmith (8); BruceFlorida (1); coal1986 (1); Cobra (1); Gazu (1); gringogreg (1); Hooker (1); markar (1); Nigh (1); redfred (2); TonyS (1); Tornado (2); zzr1200 (1)
