I have numerous power supplies which need 2 hr run times on the batteries periodically. However there is not an automatic switch over to line voltage once the battery cutoff voltage is reached. I would like something in line with the ac cord which would also monitor the batteries' voltage and return the ps to ac input once a low battery cutoff voltage is reached. The unit has a built in timer on battery usage so I would know upon a return visit if the batteries made the two hour run time. Thanks Gene
