Previous in Forum: Beraing temperatures.   Next in Forum: Pressure Vessel & Stack
API 650 Tank Primary Wind Girder Section Modulus
02/16/2011 4:40 AM
Dear Members,
I have a formula as per API 650 Cl, 5.9.7.6 (Primary wind girder section modulus):
Z = ((D2 x H1)/17) x (V/190) 2
Where; Z = Section modulus = cm3
D = Tank diameter = 30m
H1 = Tank height =16m
V = equivalent wind velocity = 181 kph
Z = ((m2 x m)/17) x (kph/kph) 2 = m3
After Calculate I got Z = 768.7 m3.
The problem is how to convert it to 768.7 cm3.
Could anyone advice us regarding this matter.
Thank you.
Pathfinder Tags: wind girder
Good Answers: 137
Re: API 650 Tank primary wind girder section modulus
02/16/2011 5:14 AM
To convert m3 to cm3 you multiply by 106 (=1003). But I don't think the formula is saying you need Z = 768 m3. There's something wrong if it is. It probably means the result is in cm3. It's still a big member e.g. a 381mm x 102mm RSC has Zxx 782 cm3.
Cheers..........Codey
