Previous in Forum: Exhaust Fan   Next in Forum: API 650 Tank Primary Wind Girder Section Modulus
Beraing temperatures.
02/15/2011 11:36 PM
Dear engineers
Can any one provide me with the data regarding pre-defined temperatures limits of bearing for 3 phase induction motors for insulation class A,E,B,F,H
Also let me know that the insulation classes used in electrical motors are their respective temperatures limits in accordance with IEC 34 standard are as follows class A (105 C),class E (120 C), class B (130 C).class F(155 C), class H(180 C).
What will be the temperatures limits for VFDs ?
Re: Beraing temperatures.
02/16/2011 12:29 AM
I don't recall ever seeing such data, and it may be hard to find. A reasonable assumption might be that bearing temp is 5-10°C less than insulation class temp (the bearings being nearer to ambient air than the motor windings).
02/16/2011 12:42 AM
"Data regarding pre-defined temperatures limits of bearing for 3 phase induction motors" or any other bearing, would come from the bearing manufacturer, not the motor manufacturer.
Good Answers: 53
Re: Bearing temperatures.
02/16/2011 1:00 AM
Bearing temp limits can not be based on insulation class but will depend on the many factors such as what is the bearing types (for example sleeve or ball) what are the specified operating temp for bearings, what lubrication is used and so on-
For example if a sleeve bearing lubricated with silicone oil will have higher temp limit than of sleeve bearing with petroleum based oils.
Register to Reply 3 comments
lyn (1); rakesh_semwal (1); Tornado (1)
You might be interested in: Audio Amplifier Chips, Ring Gages, Excimer Lasers
