Previous in Forum: Macro Camera   Next in Forum: St. Elmo's Fire
9 comments
Hotel Mode for Aircraft
02/16/2011 12:32 PM
Does anyone know where the term "hotel mode" for aircraft originated? I know what it means but I was curious how it got started. Was it an acronym, nickname, etc?
Pathfinder Tags: hotel
Good Answers: 21
Re: Hotel Mode for Aircraft
02/16/2011 1:29 PM
Never heard of Hotel Mode. Have heard of the following. Derived from the Morse Code Alphabet.
"A" Alfa, "B" Bravo, "C" Charlie, "D" Delta, "E" Echo, etc, etc.
02/16/2011 1:32 PM
As I understand it, Hotel mode is a mode of operation where the aircraft is on the ground, operating at a reduced power level for running certain systems only.
02/16/2011 1:40 PM
'Hotel Mode' allows a pilot to disengage the propeller of one turbine. This will allow the plane to sit at a gate with the engine running, providing power and air to the plane without the prop spinning.
This feature also replaces an on-board auxiliary power unit (APU), saving weight.
Like you, I have no idea where the phrase originated. I hope someone comes forward with an answer; now I am curious too.
02/16/2011 2:00 PM
Hotel mode is a term used for when the aircraft is stationary, engine running and propeller is disengaged.
I have heard that the reason for the term "hotel mode" is that is what it's called when ships in port. They run the engine at low speed to power essential systems, so the ship is like a hotel for the passengers.
J B
02/17/2011 5:36 AM
GA
from http://www.pprune.org/archive/index.php/t-289339.html
The term hotel mode is actually a nautical term. When cruise ships would pull into port, they would disengage the screws from the powerplants so that they could still get electricity to keep the ship powered without turning the screws.
02/16/2011 5:37 PM
Not to be confused with the acronym typo HOTOL...
New Zealand - Member - Member Australia - Member - Member
Good Answers: 43
02/17/2011 5:45 AM
"hotel mode" for aircraft originated from the marine industry. Ships pulled into port and disengaged the prop shaft to allow the engines to be used for electricity generation for on-board services.
Similar for aircraft where there is no ground power unit, it enables the #2 engine (non-boarding side) to be used for power (aircon and services) without the prop rotating. There is a weight and space saving advantage from not having to instal an APU. An entertaining simulation;
http://wn.com/Flight1_ATR_72_Startup_Tutorial_Hotel_Mode
02/17/2011 1:05 PM
The ships I served aboard had a continuous shaft from the turbine's reduction gears to the "screws" (props) so there was no "disengaging" of them. Turbine generators had their own turbines to turn the generators. I'm sure the setup would be similar on other ships ... you cannot possible depend on one turbine to do everything.
I'm guessing the "hotel" term came from the services you typically expect for habitability in any public or private space: electric - water - heating/cooling, sewage --- similar to what we expect in a hotel.
Just a guess about the term .. and a fact, about US Navy equipment, of which I served in both old WWII tincans and nuclear cruisers. And in hotels too!!
Good Answers: 119
02/17/2011 2:29 PM
"Ya learn something new everyday."
Never heard of "hotel mode", even after nearly 50 years around aircraft.
I'm very familiar with rotor brakes on helicopters but I had no idea about propeller brakes on fixed wings.
Hooker
Register to Reply 9 comments
AussieBob (1); Doorman (1); fixitorelse (1); Hooker (1); JBTardis (1); PWSlack (1); Randall (1); robbump (1); twoodward (1)
