Previous in Forum: Blame it on Bahrain!   Next in Forum: Getch and Gravel for a Road Bed
Air Loss in Chimneys
04/03/2007 1:13 AM
Hello,
The problem is that I have to calculate the air flow in a chimney, due to the temperature gradient between the room temperature and outside temperature. The chimney is 7 meters long and is serving a gas heating device installed in the kitchen of an apartment. The opening of the chimney is 1.50 meters from the paving. We have an air inlet of 110 mm in diameter in the outer wall of the kitchen and the heating device is a traditional opened chamber Viessman 28kw.
Re: air loss in chemneys
04/03/2007 4:33 AM
The efficiency of the appliance, its on/off ratio and the insulating qualities of the stack will determine the temperature of the gases in the chimney. The on/off ratio will determine the flow. The fuel will determine the gases' composition. The diameter, or equivalent diameter in the case of a rectangular cross section, and the roughness will determine the velocity. The temperature will determine the buoyancy. Local air pressure will have an influence, as will local weather conditions...
Er, why calculate it; what would be the meaning of the calculation?
Air flow can be measured with a suitable instrument.
04/12/2007 7:08 AM
I have to prove that the designed heating system ( opened chamber gas heater) instaled in the kitchen, is a source of air loss due to the permanent openings we have ; chemney and air inlet. Apart of the positive effect of natural ventilation, appears the disconfort caused by the cold air and it's movement.
Re: Air Loss in Chimneys
04/03/2007 9:00 PM
For what reason?
There's them that knows and them that just thinks they know, whitch are you? Stir the pot and see what rises up. I have catalytic properties I get a reaction going.
04/04/2007 11:04 AM
To calculate an amount of the airflow you need to know:
1. Temperature of outside air in intake and temperature of exhausted air.
2. Area of inlet and outlet
2. Difference in the elevation.
Then you can calculate it on principle of natural ventilation.
If you do not know how to do it, please find it through Google
04/11/2007 10:25 AM
thank you,
I will try once more to find one site by google search
Anonymous Poster (2); apcco (1); BrainWave (1); PWSlack (1)
