Previous in Forum: New method of data packaging   Next in Forum: UPS Problem
Projector Flickering
02/17/2011 1:43 AM
We are using NEC LCD projector, now some days before we noticed flickering of screen. can anyone suggest what exactly happened to Ptojector.
Good Answers: 29
Re: Projector Flickering
02/17/2011 1:13 PM
02/17/2011 4:11 PM
You didn't mention checking the lamp. Most projector lamps have a very limited life; yours may be starting to fail.
02/17/2011 10:45 PM
Usbport is right, check the bulb, also check fans and blow out dust from any filters. I have also noticed a recurring problem with Digital Light Projection TVs, which work on a slightly different principle, but both use special lamps. Always purchase the exact replacement lamp, OEM. So many people have bought what they thought was an "exact replacement" lamp, only to have to buy the slightly more expensive OEM part, and pay a bench charge to boot. (Original Equipment Manufacturer, i.e., 'Osram', 'Phillips'.)
"Achieving the impossible goal is much easier if you don't believe it's impossible." Michael Proctor
02/17/2011 10:46 PM
Have you checked the settings to assure the frequency setting is set to your country's electrical frequency, i.e. 50 Hz vs. 60 Hz.?
Engineering Fields - Electrical Engineering - New Member Engineering Fields - Mechanical Engineering - New Member
02/21/2011 1:05 AM
May setting isn't match, projector and notebook
One system
dedyamisha (1); loadshare (1); RDGRNR (1); techee1 (1); Usbport (1)
You might be interested in: LCD Switches and LED Switches, LCD Drivers, Projectors
