Previous in Forum: Overdue Update (Doyle Rotary)   Next in Forum: Solar Business
Location: Sriharikota SDSC SHAR Centre Nellore Dist Andhrapradesh India
Fire Engineering
02/18/2011 4:07 AM
how to find out gross weight of a CO2 fire extinguisher if tear weight and water capacity is given?
Good Answers: 11
Re: fire engineering
02/18/2011 5:03 AM
What's your purpose?
Re: Fire Engineering
02/18/2011 10:47 AM
1. Weigh it.
2. Call the manufacturer.
It's tare weight, not tear weight.
02/18/2011 2:06 PM
chandrahas M, are you not the Sub Officer/SHAR Fire services in Gov't of India, Dept of Space, Satish Dhawan Space Centre (सतीश धवन अंतरिक्ष केंद्र)?
This seems a question you should already be able to answer...
02/18/2011 7:48 PM
My, my. What nice work.
02/18/2011 7:28 PM
A CO2 bottle is filled by MASS this will be Gross weight minus Tare weight and the info WILL be stamped on the bottle.
The volume and density of liquid co2 varies with temp.
The density of liquid co2 is around 666 grams per litre @ 82F...and the fill ratio is normally 0.666.
A CO2 bottle with a volume of 3 litres ( water capacity ) will therefore contain 3*0.666 = 2kg's of liquid co2.
02/18/2011 7:48 PM
EDIT ...Page 20.
Register to Reply 6 comments
Doorman (1); lyn (2); Noudge79 (1); woodygb (2)
