Previous in Forum: Roof / Tank Sealing Systems   Next in Forum: Kevlar Rod Attached to Kevlar Plate
Loads On Existing Telecommunication Towers
02/18/2011 6:54 AM
how do you determine whether an existing telecommunication tower is overloaded or not? the calculations involved with the equipment i.e antennas
Re: Loads On Existing Telecommunication Towers
02/18/2011 8:24 AM
1. Consult the original designer.
2. Hire an engineer who can perform the proper analysis.
Under no circumstances should you try to do this yourself!!
02/28/2011 5:57 AM
First off, if you are not a civil structural engineer yourself then Guru is right that you need to hire a professional Engineer to do this job.
If you are a structural engineer then you shall get a full structural survey carried out to establish the existing loads and the existing member sizes and details along with its foundations; then you need to analyse the tower and its foundation for its capacity; compare the existing capacity to its existing loads. Then you'd find out if its overloaded or any remaining capacity is left over to take any further loads. Hope this lelps else email me back.
You might be interested in: Antennas, Towers, Masts and Poles, Cooling Towers
