Previous in Forum: Crane Testing and Derating   Next in Forum: HVAC System Upgrade
Autocad Drawing
02/19/2011 2:34 PM
how can i insert picture in autocad drawing without damaging the picture in the autocadd drawing when changing the path of the picture???
thnx
Re: Autocad Drawing
02/19/2011 7:55 PM
You are not explaining well enough.
What type of "picture"? Is it an image file? jpg? bmp?
What do you mean by "changing the path of the picture"?
You cannot expect a valid answer if you don't put in the effort required for sufficient detail.
Re: Autocad Drawing
02/20/2011 4:57 PM
yes i wonna insert picture (.jpg) changing path mean:
when i take the drawing on other computer or delet the picture or chang its location on the same computer.
thnx for attention
Re: Autocad Drawing
02/20/2011 9:16 PM
You are still not explaning well enough to understand what you are trying to do.
Hobbies - Automotive Performance - New Member Hobbies - CNC - New Member
Re: Autocad Drawing
02/20/2011 3:59 PM
If you insert your picture as an OLE object, You can't. You might also wish to take a gander at the documentation, if you already have not: http://docs.autodesk.com/ACD/2010/ENU/AutoCAD%202010%20User%20Documentation/index.html?url=WS1a9193826455f5ffa23ce210c4a30acaf-5c6a.htm,topicNumber=d0e153148
It is better to fail in originality than to succeed in imitation.
Register to Reply 4 comments
Economist (1); mariamn (1); Mikerho (2)
