Previous in Forum: Short Circuit   Next in Forum: Multi Axis Controllers
Switchyard interface
02/22/2011 4:53 AM
We have 2 switchyard's.Both are interconnecting by a SF6 breaker. Interconnecting breaker capacity is 3150A. For both the switchyard's voltage level is same, but switchyard 1 bus current carrying capacity is 2000A whereas for 2 capacity is 3150A. In this case, how the load transfer will takes place?
Life is for one generation, a good name is forever.
Pathfinder Tags: Bus sharing
Re: Switchyard interface
02/22/2011 12:17 PM
Add all the concurrent load amperages on each side of the bus; that will tell you how it balances.
02/24/2011 5:49 AM
this means they are not identical capacity switchyards, they are built and interfacing is provided only as a backup for the smaller capacity one, where viceversa is not allowed.
having same voltage doesn't means are of the same capacity, you have to provide more details in order to get a better idea, as which is the incoming and how they are interconnected and their loads,etc.
Register to Reply 2 comments
You might be interested in: Circuit Breakers, Load Centers, Bus Plugs
