Previous in Forum: Basics of Instrumentation   Next in Forum: Heavy Equipment Hour Meter
Ethernet CAT6 cable
02/22/2011 11:18 AM
Greetings
Please advice
If CAT6 ethernet cable can be direct buried under ground for less than 80 meter.
Are surge protectors required at both the end
Thanks
Fareed
Pathfinder Tags: CAT6 Ethernet cable
Good Answers: 58
Re: Ethernet CAT6 cable
02/22/2011 11:48 AM
Fareed,
Yes, you can direct bury if you purchase direct bury cable.
Surge suppressors could not hurt.
Try Google and enter "direct burial CAT 6 cable".
Good Luck!
02/24/2011 12:00 AM
Cat6 is very high speed digital transmission cable. The equipment connected to it normally contains the static discharge protection. You are not qualified to add to that. Any such attempt would simply mess up the functioning of the cable.
Register to Reply 2 comments
