Previous in Forum: Acceptable Leakage Rate For Nitrogen Helium Leak Test   Next in Forum: Stainstess Steel Chemical Reactor Finishes
thread specification
02/23/2011 5:15 AM
Hi,
A hole with internal threading is specified as M8x1
does 8 represent the maximum diameter or minimum diameter (in mm).?
New Zealand - Member - Member Australia - Member - Member
Good Answers: 43
Re: thread specification
02/23/2011 5:38 AM
This may help you
02/23/2011 6:53 AM
M8 would specify a maximum (outer) diameter close to 8 mm, but you need to consult a thread standard to get more exact. (I'm not sure that M8x1 would be the same as M8x1.25, which seems to be the "normal" combination.)
Good Answers: 130
02/23/2011 6:56 AM
8 would represent the screw O.D. - as it does in say 5/16th imperial.
1mm is the 'fine' series pitch, so the hole to be tapped would be drilled 7.00mm
Very few people use 'fine series' metric - it is truly 'fine' - it's for real precision work and 0.01 tolerances.
However M8 (as seen in the table above) is commonly 1.25 pitch - meaning the hole would be drilled 6.75 mm dia. (Likely in production 6.8)
(numbers from ZEUS precision - maybe you should buy one)
02/23/2011 10:17 AM
Nominal Dia minus the pitch equals the tapping drill size.
34point5 (1); Anonymous Poster (1); AussieBob (1); Tornado (1)
