Previous in Forum: To Save the Globe with Floating Energy Barges (FEB)   Next in Forum: Spent Nuclear Rods for Power Production
Welding Steel Pipe
02/24/2011 4:21 AM
sir,
what metal will use for steel pipe welding.
thanks
muhammadshamim
Re: welding steel pipe
02/24/2011 4:23 AM
Cheese.
02/24/2011 4:23 AM
Steel metal. Normally filler metal is the same as the parent metal.
Good Answers: 101
Re: Welding Steel Pipe
02/24/2011 9:29 PM
Minced beef pizza & hamburger.
Good Answers: 179
02/25/2011 8:50 AM
Bacon Cheeseburger Pizza.....delish!
07/27/2012 5:38 AM
Welded Steel Pipe Our welded steel pipes include butt-weld pipes, arc welded tubes, bundy tubes and resistance- and other pipes. They have many features such as high strength, good toughness and lower cost & higher production efficiency than seamless pipes. They can be applied to transportation of the water, oil and gas.
Anonymous Poster (1); btwlzyq (1); CaptMoosie (1); DVader1000 (1); lyn (1)
