Previous in Forum: Welding Steel Pipe   Next in Forum: Value Engineering Power Transmission
46 comments
Spent Nuclear Rods for Power Production
02/25/2011 8:46 AM
Why aren't, we,(the U.S.), using spent nuclear rods to make power? Some European countries have been doing it for a while. The plus side is power production with no harmful emissions (unless if blows up, of course) and the lowering of the half-life of the spent rods. Wouldn't it be nice to not have to store dangerous radioactive material for the next fifty thousand years?
There's bound to be a downside. What is it (I hope it's not the "Conspiracy Theory" again)?
HAVE SOME FUN TODAY,
PAPADOC
RMFR
Re: Spent Nuclear Rods for Power Production
02/25/2011 2:30 PM
I don't specifically remember the use of spent nuclear rods (at least, not without some reprocessing) being used in foreign reactors. But there are several alternative technologies out there (pebble reactors, breeder reactors, etc.) that seem to not even be discussed in the USA.
Cynic that I am, is that because the big companies trying to sell nuclear power in this country see more profit in the traditional pressurized water designs?
Good Answers: 153
02/26/2011 8:45 AM
Breeder reactors may not be discussed in the US, that does not mean that they are not used. Are far is I know the only way to make plutonium (good for bombs, but too concentrated for reactors so there is no practical way to extract the heat) is in a breeder reactor. The US has lots of warheads, therefore the US must have a breeder reactor, and strategically for security of military supply, must have at least two.
All other reactor designs use isotopes of uranium U235 and to a lesser extent U233, which make up about 0.7% of mined uranium. The rest is mostly U238 but there are actually 6 isotopes in all.
Power reactors operate at concentrations of between 3 and 5% so the uranium has to be enriched by converting it into uranium hexaflouride UF6 and subjecting it to either a gaseous diffusion or centrifuge process to increase the concentration. In Europe used fuel rods are recycled because it is easier and cheaper to start at 3% and enrich to 5% than starting at 0.7% and enriching to 5%. It also avoids having to arrange long term storage for used fuel rods. There is an argument that transporting used fuel back to the reprocessing centre is dangerous and open to terrorist attack, but considering that bomb grade material is typically 90% U235, I do not consider this argument valid. Why the US does not reprocess is a complete mystery.
Finally the military use of depleted uranium for ordinance. Depleted uranium is what is left after you have separated out the quite radioactive U235 and is composed of the only very slightly radioactive U238. If you dug up rocks from somewhere that has high background radiation, like Aberdeen, Scotland and threw them at the enemy, you would be scattering more radioactivity around the environment than chucking U238. It is used because it is 1.7 times heavier than lead, so for the same weight and speed of shell it has 1.7 times the penetrating power and this is needed to penetrate composite armouring like Cobham armour. In both Kosovo and Iraq where it has mostly been used, the enemy did not have sophisticated armour, so it was not required. Its use just created another thing for a misinformed environmental lobby to bleat about.
Good Answers: 53
02/26/2011 11:59 AM
jhhassaciates presumption "therefore the US must have a breeder reactor" is an assumption based on ignorance. Evidence of this is that the Manhatten project produced tons of Pu without a breeder.
There are other factual errors in this post.
The use of DU ordinance is a topic unrelated to nuclear fuel reprocessing.
02/26/2011 6:30 PM
Actually, the Manhattan project used mostly reactor bred plutonium. They did begin research using plutonium made in a synchrotron, but the process is far too slow for production purposes.
The manhattan project produced far less than a ton of plutonium by non-breeder-reactor means. I would wager that the total of all plutonium ever produced by any synchrotron is still less than ton.
The comment concerning the US using a breeder is based on sound logic and is true. The Hanover sight in Oak Ridge is one such breeder reactor. I believe Los Alamos probably has one as well.
If you are going to slam people claiming inaccuracies, it would be wise to fact check your own assertions before flaming away... :-)
Good Answers: 53
02/26/2011 8:39 PM
eLF,
The Manhattan project produced plutonium in graphite moderated nuclear reactors. The reaction converted some of the uranium to plutonium. These reactors consumed more fissile material than new fissile material was generated, therefore they were NOT breeder reactors, you can fact check this yourself.
I can assure you that the Manhattan project produced greater than a ton of plutonium by non-breeder reactor means.
Please note that I have not stated that the US has never had a breeder reactor. And I disagree that it would be sound logic to make such a statement based on the fact that I am somewhat ignorant regarding US breeder reactors.
I do like your final sentence and I am in complete agreement with at least that much of your post... ;)
02/26/2011 9:39 PM
Ace, Your been the closest to correct throughout this discussion, and suitably cautious when uncertain. Everyone would potentially benefit from reading Wikipedia's articles on "Breeder Reactors" and "Fast Breeder Reactors".
"For a successful technology, reality must take precedence over public relations, for nature cannot be fooled." -Richard Feynman
03/02/2011 5:07 PM
I was in error. I failed to make the distinction between Pu bred in a reactor (as opposed to a Cyclotron....no limit do my misstatements it seems) and the use of a breeder reactor to create the Pu.
I appreciate the correction and opportunity to upgrade my understanding.
02/27/2011 9:31 AM
A Cyclotron .....and it was a many year multi location project
klearzen
Canada - Member - New Member
02/27/2011 11:21 AM
I'll bet that it was - just look up the "history" of the Manhatten project as extended by Ace. - Loupy.
Have a Happy! ;-)
Good Answers: 153
02/26/2011 7:16 PM
You are perfectly right of course. How remiss of me to not think that setting off a bomb in the Arizona desert and then scraping up the result with a spatula is not a perfectly reasonable and economic method for the commercial production of plutonium.
02/28/2011 11:22 AM
Hanford Washington.
03/01/2011 10:18 PM
I think we are actually discussing "enriched uranium" in the fuel rod context. I was advised by Canada Nuclear that the most recent design of CANDU reactor has been run on "spent" fuel from a US - PWR.
I did not think to ask about either Plutonium or DU - but then that wasn't the question here, was it?
They did however confirm that the new design also burns Thorium, in case anyone ever gets interested in a 'lower half-life' nuclear fuel.
Out in a Bowt
03/02/2011 7:32 AM
Good information. Since using new rods is cheaper than using spent rods, maybe, we (US) are just selling our spent rods to other countries to get rid of them. I think we're getting closer to figuring out why the US doesn't have spent rods power plants.
Now, if someone knowledgeable about the French spent rods power plants would explain the economics of their system, it would be very helpful.
Good Answers: 53
03/02/2011 9:34 AM
Papadoc, The primary reason that it makes sense for the French to reprocess nuclear fuel is that it greatly reduces the volume of waste that they must deal with. The reason that commercial reactors in the US don't reprocess is political (see post #3).
03/02/2011 6:04 PM
How much coffinite (or uraninite) do they actually have in reserves to mine in France? It might just be cheaper than paying foreign nations to supply the raw ore or processed material. On the other hand in nations with large natural deposits of readily accessible ore and processing facilities, it could be cheaper to process the new rods, and sell the old ones at a huge discount to France (even at a huge discount it would be cheaper than disposal). Though I am sure there are political interests on both sides that lobby for one or the other technologies. In the US we have substantial mining and resource processing interests, so they favor the side that directs more money to such activities. Within France, I suspect there is not a lot of active mining occurring (in relative terms), so the strength of those interests as a lobby may not be as formidable. Then there is also public opinion, no community in the US is going to let you dump even very low level nuclear waste in their area, if they can oppose it, and NIMBY is king in the US. In France the national politics are less concerned with the interests of local people, as long as it serves an interest of the majority (or at least doesn't get them rioting in Paris). It just makes more sense to make a new product for our use and sell our waste rather than have to dispose of it, then to clean and reprocess the waste into a smaller volume of useable material.
Good Answers: 153
03/03/2011 4:58 AM
I am British, having a go at the French is a national sport over here, but your comments are wide of the mark.
France produces 75% of its electricity from nuclear power. Only 17% is produced from recycled fuel, and all of that comes from their own reactors, they do not "buy" in. France is the worlds largest electricity exporter generating an annual income of about €3billion. The policy in France was to create a secure energy supply and worldwide there are few that are less vulnerable. They are leaders in reactor research, design and development and are currently building third generation reactors.
You do not "sell" spent nuclear fuel, you pay someone to take it away. There are very few plants for fuel recycling so consequently the price for recycling is high. Many contracts also stipulate that you must take back both the recycled fuel and any residuals left over after recycling.
03/03/2011 1:46 PM
Oh yeah, I knew France derives a huge majority of their electricity from Nuclear power. I didn't know they exported the electricity. Though I guess that makes sense, if they generate excesses in a smaller localized economy (France being slightly smaller than Texas, slightly larger than Sao Paulo) with major infrastructure interconnections, it makes sense to export it. This is very similar to the way some larger countries in the Americas export electricity from one State where excesses are generated to other States where industry or large numbers of people can use the excess. Nuclear power is a stable source of energy less influenced by short-term market price fluctuations, but not sure what you mean by vulnerability, as that depends on the attack on the system you are considering. Obviously, a war or terrorism would present a different set of circumstance in which nuclear facilities would be prime targets if you wished to decimate a population, than say economic conflicts and market price fluctuations. Though there is long-term vulnerability (that may not be considered) since much of the uranium is mined in places like the Congo or Former Soviet Union (though I understand with the fall of the Soviet Union the market was flooded with a lot of processed uranium and essential no mining and refining of ore occurs currently). They still have to purchase much of the raw resources (fuel) in some form from someone else outside of France.
I used the term sell in the sense that if you transfer a product at less cost than it would cost to dispose of that product, you "sell" it in that you make a profit in terms of less loss over standard. so the question becomes, if reprocessing the spent fuel is expensive, how much does it cost the French to get new fuel and how do they compare? How would this compare in the US, where the resources are directly available from with in the country or adjacent Canada? The cost point comparison might be less competitive in the US than in western Europe, or it may not? It would be nice to see some actual costs for these.
Good Answers: 153
03/03/2011 2:34 PM
By building relatively small power stations, they have 58, the loss of a few would not disrupt their supply. They generate about 25% over their national consumption and this is the excess that goes for export. The stations themselves are bomb hardened both to contain an internal blast and defend from an external one, and are defended by paramilitary force that would make the green berets look like a Sunday school class.
Naturally the French government is cagey about its strategic uranium stockpile, but estimates range from 80 to 120 years worth based on current usage (excluding their weapons grade material which could be diluted for use in power generation).
My only direct involvement in the industry dates back to the DFR and PFR programs based at Dounreay back in the late 1960s / early 1970s, so my knowledge of costings is woefully out of date.
03/03/2011 4:11 PM
hmm, that kind of makes me wonder what the US and Russia have in reserves, considering the huge amounts of nuclear weapons being decommissioned.
I thought all nuclear facilities had highly trained guards (I know the ones at Diablo Canyon practice shooting at nothing a lot, well targets I should say). Though I think the comparison to the Green Berets is probably a bit of an exageration, maybe the Rangers or Pararescue.
Bomb hardened is a nice sounding word. I can remember watching those new reels of US bombs penetrating bomb hardened underground bunkers in Iraq. I wonder how many of those would a country capable of launching and invasion and major offensive on french soil may have (let alone the ones that could just bomb France from a distance and never have to send troops)? This knid of makes me think it really means hardened agaisnt poorly planned terrorists and spec ops.
02/25/2011 3:21 PM
I'm of the understanding of the military's use of depleted uranium (DU) in armour piercing shells they were (are) using in Iraq.
Apparently it does the job, but does leave behind quite a hazardous radioactive mess, that eventually seeps it's way into the groundwater, as well as causing long term respiratory, tissue and nervous system damage, and adds carcinogenic active contributing factors to the troops who are unfortunate enough to come into contact (or inhalation) with the stuff.
And YES, I wish that it vould be reprocessed into usable fuel to generate power, as you have suggested. - Loupy.
Have a Happy! ;-)
Good Answers: 11
02/26/2011 7:00 AM
Looks like Boobby Brown and the Pinks have been through and rated us all. (See Australian fringe politics take charge)
I'll try and unpoof the ratings.
02/26/2011 2:51 PM
Dear Emjay4119, I do NOT rate the contributions of the participants of this, or other forums of the discussion presented. I only try to express my understanding of the said issue at hand. A rebuttle of my comments are well appreciated and welcomed. I DID NOT give you the OT! - Someone else did.
Besides that point, I am enjoyed as well as enlightened by some, if not most of the other replies to this post - Please do not condemn, without an understanding of the intention of the contributor to any discussion. - Loupy.
Have a Happy! ;-)
Good Answers: 11
02/26/2011 5:38 PM
I have not rebutted anything you have said. I also did not think you put the OT there were several OTs all through the thread when I logged on last night including on your post. There are a hard core that do this sort of thing whenever any mention is make about nuclear energy.
Thanks for getting back.
02/27/2011 12:00 PM
Thank you Emjay4119, I still have childhood memories and nightmares about a squadron of B-52's taking off from the northern States to attack Russia, and a retaliatory strike of thier 'Bear' bombers returning the favour.
I guess that I'm another one of millions of victims, like yourself, who was indoctrinated into the fears of the cold war - Is it really over yet?
And yes, up here in Canada, we were also, as were you in the U.S.A., instructed in primary school to duck and cover, underneath our desks. (as if that were to be any consolence to being blasted away by the 100 Mton special delivery package conveniently dropped off in your neighborhood).
I suppose us older folks still have the bejeesus scared silly straight out of us, as to what an absolutlely insane time the 1950's to the late 1990's were to endure.
Is it really all over, and can I finally get a good night's sleep, without worrying anymore? - All the best - Loupy.
Have a Happy! ;-)
Good Answers: 53
02/25/2011 8:48 PM
The reason the US refers to the valuable resource of used nuclear fuel as "waste" instead of reprocessing it for additional power production is purely political.
http://www.pbs.org/wgbh/pages/frontline/shows/reaction/readings/rossin.html
3. THE CARTER POLICY
On April 7, 1977, President Jimmy Carter announced that the United States would defer indefinitely the reprocessing of spent nuclear reactor fuel. He stated that after extensive examination of the issues, he had reached the conclusion that this action was necessary to reduce the serious threat of nuclear weapons proliferation, and that by setting this example, the U. S. would encourage other nations to follow its lead."
Good Answers: 11
02/26/2011 4:28 AM
Links seldom warrant a GA, but that one does.
Carter. What a thing, his pro tobacco policies, UGH.
Truman saved millions of lives by ending WW2, painful but true.
Carter with his endorsement of Big Tobacco killed an order of magnitude more than Truman could save, he is the gift that keeps on giving (to big tobacco), then he appeased the Soviets, then this.
George Dubbya Bush is a modern day pariah in many eyes, but in reality he is almost a nobel laureate compared with Peanut Carter.
02/26/2011 5:36 AM
The ghost of Cater continues to plague us... and he isn't even dead yet.
Johannes
02/26/2011 4:51 AM
Quite a few years back, I remember reading about power bring generated using waste fuel.It basically consisted of a coil around the rods,and an oscillator circuit to convert the voltage into AC.The theory was the neutron emission would produce voltage when passing thru the copper coils,and the circuitry would modify it to a usable level.
Anyone else hear of this?
Good Answers: 21
02/26/2011 6:41 AM
There are a lot of factors that govern the reprocessing of fuel rods. Fuel rods used by the military are of a much different quality then say for the power plant down the street. Though most of the information of military fuel rods is fairly classified information, you can assume that they are reusing them to the best of their abilities for the use intended. As far as the rods used in domestic power production, I believe these are in fact reprocessed as much as possible. The type and quality of materials dictates what can be done to reconstitute the enrichment, along with the amount of decay.
Lets not get to gun-hoe on the Nuclear stuff just yet. There is still a lot of bad things that can happen to us from these materials.
Good Answers: 53
02/26/2011 12:26 PM
You can NOT assume that spent US fuel rods are being reused to the best of their abilities!
In fact I have seen many naval sub reactor cores being transported for disposal to a burial area.
There have been operating facilities in the US for over ten years that produce reprocessed fuel assemblies from and for foreign countries. But it would be a federal violation to use fuel from or in any US reactor. I worked at one.
fixitorelse, your belief based on assumption is factually incorrect. Don't take my word for it, do some research, and only believe what you can verify. There is a lot of BS on the internet presented as fact that is simply not accurate.
Good Answers: 21
02/28/2011 9:19 AM
I wrote a research piece on this some years ago, that was published. Do not assume that we all are not aware of what is going on with the materials coming from the nuclear industry. I chose not to be totally negative on the subject, but cautionary.
Good Answers: 53
02/28/2011 9:49 AM
Re: "Do not assume that we all are not aware of what is going on with the materials coming from the nuclear industry."
Fixit, You seem to be saying that - We should assume that we all are aware of what is going on with the materials coming from the nuclear industry.
That statement seems ridiculous and poorly communicated coming from a published technical writer. Were you an advocate for making verifiably inaccurate assumptions in your research piece as well? Or have I completely misinterpreted your intended meaning?
I recommend that in the future you should be less concerned about negativity and instead choose to be accurate on the subject.
02/28/2011 11:50 AM
Actually, if you took the negative of his statement it would not imply all are aware but rather that some are aware, as it states we all are not aware. Which I think indicates some persons on the forum are aware.
02/26/2011 7:48 AM
Technology for reprocessing and using spent fuel rods has only become available recently (month ago). Have a look at this link.
http://www.industryweek.com/articles/china_discovers_nuclear_fuel_breakthrough_23561.aspx
02/26/2011 9:15 AM
Re: Technology for reprocessing and using spent fuel rods has only become available recently (month ago). Have a look at this link.
If you've seen my comments in some other thread requesting more rating possibilities for posts, I guess I'd like to add to the list and include: "humorous" (or "sarcasm" or something). I'm sure for a lot of our guests, it is sometimes hard to catch the sarcasm that an American might use in a post.
I guess I don't know for sure if this is intended to be sarcasm or is just a case of a misplaced "only". Such technology existed before now, this might be a new approach to such reuse. Rewriting the statement to read as follows might be more accurate. (Boy, I had a headache yesterday, somehow I must be bouncing back from it today, and showing that by overreacting. I'll go take a Valium or something.)
"A new technology for reprocessing and using spent fuel rods has become available recently (month ago)."
02/26/2011 9:30 AM
I think this is wrong. When I was working at Argonne National Lab in the 1970s, they were developing a remote control facility for reprocessing of used nuclear reactor fuel rods. The actual facility was at the Idaho test area. I think they were successful, but it was turned off for political reasons.
Lehman57
03/01/2011 7:31 AM
If this is new, what technology is France and some other countries using to make power from spent fuel rods?
02/26/2011 9:15 AM
The recycling of used nuclear fuel rods is possible, but for political reasons it has only low acceptance.
- Some intententions go to eliminate any risk that materials (used fuel as well te recycled) could be missused.
- Finaly, the recycling chimistry makes radio-active waste what is not accepted by
many ecologist groups.
For the ecology, the advantage would be that smaller quantities of uranium could be
extracted of the earth, a process which brings low radio-active materials in the environnment, too.
02/26/2011 4:25 PM
All nuclear power plants in the US use light water reactors. This is a mature technology, well understood, and well run. To illustrate here is the contrast between 1978, the year before the TMI accident, and 2009, the most current year with data:
The differences are a somewhat larger average plant size, and then knowledge and attention to detail in operation.
Virtually all fresh fuel for these reactors is uranium, enriched in the isotope U-235 to on the order of 4% from the natural uranium condition of 0.71% U-235 and the balance U-238. In a typical case, a little over one third of the reactor fuel is replaced every two years, with the same amount of "spent fuel" removed and stored.
When the reactor is running, power is chiefly produced by fissioning the U-235, and by fissioning Pu-239 that is continuously being produced by neutron absorption in U-238 followed by a couple of beta decays.
When the fuel is spent the readily fissionable isotope amounts are at most about 0.4% U-235, 0.4% Pu-239 and 0.1% Pu-241. The U-238 has gone from 96% of the original fuel heavy metal mass to about 92%. Most of the remaining mass is fission products. A small amount of mass has been converted to energy, which is the point.
Historically, any use of this spent fuel in a light water reactors involves chemically separating out the residual plutonium and introducing it into new fuel, reducing the amount of uranium enrichment needed. That this isn't done very much is for following reasons:
1. It's generally considered more expensive than simply mining new uranium and enriching it.
2. Proliferation concerns, since the primary aqueous separation process is PUREX, the same process used to separate plutonium for weapons use.
The primary "conspiracy" is to produce electricity at its lowest practical and safe cost.
One day, the cost of uranium will go up, and reprocessing cost will go down to the point where it may be practical to invest in the infrastructure to do routine chemical separation of spent fuel as a nuclear fuel source.
Alternative aqueous and electro-refining techniques are being investigated that provide higher proliferation resistance as well as lower costs.
Alternative reactor design are also conceptually available that provide more complete utilization of uranium resources.
None of this is accomplished with a simple sweep of the hand nor is it prevented by simple conspiracy. See also what it took for light water reactor technology to mature as discussed above. While some government funded R&D is involved now, market forces with all impacts considered, should primarily decide on commercialization of energy resources, nuclear or otherwise.
There is also certainly a history of bogus and fear-mongering political impediments. It's not a bad as it once was, but we still have some growing up to do.
Good Answers: 11
02/26/2011 5:58 PM
I was wondering if you could answer this one for me. In the process of enriching from 0.71% to 4%, where does the extra U235 come from?
02/26/2011 6:40 PM
Basically, what you end up with is a bunch of depleted uranium (DU) with a U-235 fraction of only 0.2% to 0.3% that you've taken the U-235 from to make the 4% enriched source. So you can imagine how much DU you get when enriching to over 90% for nuclear weapons and other military uses.
Good Answers: 11
02/26/2011 9:26 PM
Thanks.
Sounds expensive.
03/01/2011 7:42 AM
What is the cost per kw for current nuclear power plants?
What would be the cost per kw for nuclear power plants using spent rods?
In the countries that are using spent rods, how much more does the power from the spent rods power plants cost than the existing nuclear power plants?
Where I live, we get power from nuclear, natural gas, and coal power plants. My power is about $0.10 per kwh.
03/01/2011 8:39 AM
I calculated this once for a nuclear plant built by my local utility. That was probably 20 years ago, so I hesitate to quote any figures (my memory isn't that good).
What was most interesting, though (to me) was the difference between fuel cost and total cost--the fuel cost was tiny--some fraction of a penny--a very small fraction of a penny, iirc.
Not to say that I have anything against safety, but the carrying cost and such on the $4 B investment was the big cost.
Good Answers: 53
03/01/2011 10:00 PM
Papadoc,
I know this does not answer your question, but the cost per unit of energy varies widely from plant to plant regardless of the fuel source.
The information I would like to provide is that it is less costly to produce fuel from "fresh" uranium. However reprocessing has the benefit of recycling nuclear waste into a useful product. This waste presents enormously expensive technical and political problems and could be reduced to around 15% of its present volume by reprocessing.
It is my personal belief that the additional cost to reprocess spent US nuclear fuel would be more than offset by the economic and environmental benefits.
02/26/2011 6:23 PM
I thought they were trying to get away from using the old rods and are now going to floating iron particle style rods now
Register to Reply 46 comments
Ace Boeringa (7); Anonymous Poster (3); edouard1 (1); Emjay4119 (5); fixitorelse (2); Flee to Me reMote elF (2); jhhassociates (4); Johannescnc (1); klearzen (1); Lehman57 (1); Loupy (4); N&P (3); PAPADOC (3); RCE (5); rhkramer (3); snowboy (1)
