Previous in Forum: Evacuation Speakers in Barking   Next in Forum: Line Protection
8 comments
Skin Effect
02/24/2011 4:36 AM
For a stranded round conductor what is the generalized equation for Skin effect factor K.
Re: Skin effect
02/24/2011 4:45 AM
Depends on voltage and frequency; please specify further.
Re: Skin effect
02/24/2011 5:26 AM
if S= skin effect
d= diameter of the stranded conductor
f= frequency of the system under consideration
then K=f(S,d,f)
Now, i want to know the formula f(S,d,f)
Re: Skin effect
02/24/2011 9:33 AM
Huh? K=f(S,d,f)?
Save us all some time and look here.
Good Answers: 119
Re: Skin effect
02/24/2011 5:17 AM
Some equations provided here.
http://en.wikipedia.org/wiki/Skin_effect
Re: Skin effect
02/24/2011 11:17 AM
Whoops!
Sorry mjb1962853. I see now I posted the same link as you did. I didn't intend to step on you. I hate looking like a spammer.
Good Answers: 119
Re: Skin effect
02/24/2011 4:35 PM
No apology necessary . No harm done. The OP might even visit the site if more than one response suggests it. Regarding these types of questions, I'm wondering if certain countries just cannot access some of the search/information sites we take for granted (Goggle,Wiki, etc.).
Re: Skin Effect
02/24/2011 9:42 AM
I have never used the shortened form, as it's only an approximation. The above link to an excellent article gives much more detail. I used this for calculating loss over "Copperclad" transmission lines, and it was accurate every time. "Copperclad" had steel inside for linear strength, and copper outside for improved conductivity at higher audio frequencies. Litz is great for coil winding where high Q is needed, but only in the MF, HF range. When you get a bit higher, silver plated conductors are necessary.
Examle, the interior of VHF and UHF cavity filters.
Good Answers: 119
Re: Skin Effect
02/24/2011 4:41 PM
"Stranded round conductor" skin effect (skin depth) is basically the same as a solid round conductor UNLESS all individual strands are electrically insulated from each other. This special type of stranded wire is referred to in post #5 and is called Litz wire.
Register to Reply 8 comments
amitabha0107 (1); Dave Simpson (1); Doorman (2); mjb1962853 (3); Tornado (1)
