Previous in Forum: Welding on Vibrating Structures   Next in Forum: Eddy Current Testing
Welder Re-Qualification Requirment
02/25/2011 10:29 AM
what is the criteria for requlification of welder- or other words , on how much percentage rejection of weldment , welder should go for requalification - ( rejection per lenght of joints/ number of filims)
United States - Member - Member Engineering Fields - Manufacturing Engineering - Member Hobbies - Fishing - Member
Re: Welder Re-Qualification Requirement
02/25/2011 3:22 PM
There is not a hard standard - It depends on how much repair work your willing to accept.
Depending on the initial "qualification" procedure (compliance to which code), re-qualification may not be the answer. Additional training or possibly re-assignment may be required.
AWS specifies re-qual if longer than 6 months elapse without striking an arc in the qualified position.
"Stepping up to the plate" is not enough, you have to swing to get a hit!
Reply to Forum Thread
