Previous in Forum: One 75-Watt Bulb   Next in Forum: DC source for transformer
Induction Motor At Diffrenet RPM
02/26/2011 11:08 PM
what will happen if two induction motor (which use as industrial vibrator) are of different rpm connected in parallel.
Re: induction motor at diffrenet rpm
02/26/2011 11:11 PM
If the number of their respective poles is in inverse ratio to their rpm's, there will be no serious issues.
Good Answers: 53
Re: induction motor at different rpm
02/26/2011 11:38 PM
Nothing will happen if question is posted with out clarity, It will only confuse to other people,
What do you mean by connected in parallel? electrically parallel or do you mean their shafts are coupled? or something else?
Good Answers: 804
Re: Induction Motor At Diffrenet RPM
02/27/2011 10:10 PM
If connected MECHANICALLY in parallel, the faster motor will attempt to drive the slower one and cause it to regenerate, but with the effect of probably overloading the faster one, unless it is larger by a factor of the TOTAL load requirement PLUS the total power capacity of the smaller motor.
If you didn't understand what I just said, you are in over your head. Hire a professional.
JRaef (1); rakesh_semwal (1); Tornado (1)
