Previous in Forum: Gate Valve & Water Meter Proper Installation   Next in Forum: BPV Code: Section VIII Division 1: Self Directed Interactiv?e Cd-Rom Training Pr
10 comments
Inertial Force
02/27/2011 2:51 AM
I have 2 doubts and pls try to help me out of this..
DESCRIPTION : The set of 10 trolleys mounted on the rails,are pulled with the load of each 5 tones by a winch for a distance of 3 meters. These trolleys are inter linked by a bow shackle and pin joint. This bow shackle and pin is not tightly fixed.These trolleys are pulled with the velocity of 6m/min and and pull load of 4.5tones (coefficent of friction is .05) for a distance of 3 metres and left. I know that they move some little distance due to INERTIAL FORCE.
MY QUESTION IS,
1. WILL EACH TROLLEY MAY COLLIDE AT THE BOW SHACKLE REGION WHEN IT IS STOPPED DUE TO ITS OWN INERTIA AND NO BRAKING IS APPLIED..
2. if the stopper with the help of sprinds or hydraulics were used will this sounds due to collision of the bow shackles and pins can be prevented or not..
My ultimate aim is to stop the trolley and that will produce no sound, and implement the cheapest thing.
Good Answers: 181
Re: Inertial force
02/27/2011 4:53 AM
I would have thought rubber buffers would be the quietest.
Re: Inertial force
02/27/2011 6:48 PM
ya right Mr.Tonys. My intension is to stop banging of the trolley on to the stopper. So, what i mean is i need the trolley to stop on its own inertial force. My doubt is will the trolleys will collide each other and produce sound.
lets come to your point, even if we use rubber stoppers at the end wont the trolleys collide each other?
Good Answers: 183
Re: Inertial force
02/27/2011 6:27 AM
Values are not consistent: 10*5*0.05= 2.5 not 4.5. If you have to pull with 4.5 then friction is higher than 0.05. The collision can occur due to variation between friction at different trolleys and cannot be avoided. So that the suggestion of rubber damper is justified. But if the pins and shackles are not tightly fixed noise can be generated. Why not use silent blocks (sleeves with rubber in between) ?
Good Answers: 181
Re: Inertial force
02/27/2011 9:21 AM
Nice idea. GA
Re: Inertial force
02/27/2011 6:41 PM
guru,its a total load of 85 tones and friction factor is .o5.
my doubt is that will those trolleys will hit and produce sound or not..
Re: Inertial force
02/27/2011 9:16 PM
I think the OP is asking a slightly different question.
When the trolleys are released they will coast to a stop. If they are allowed to free-wheel then (provided all are identical in Coeff of friction) they will all slow equally and in unison with each other and there would be no bumping.
(In an ideal world this might be possible.)
Re: Inertial Force
02/28/2011 5:40 AM
You might consider turning the multiples into a singular by bracing the distance between the trolleys so no forward movement occurs on the shackle and pin. It still has the same drag and weight but no noise would result because there would be no contact..
Torque is not cheap
Re: Inertial Force
02/28/2011 12:45 PM
The best way to avoid the collision of the end trolleys into the ones in front is to stop the forward motion by applying the brakes to the last rear trolley only. This keeps tension along the line and prevents any trolley from rolling into the one ahead of it.
This is cheaper than applying brakes to all trolleys. one could even add a brake trolley to attach to the last trolley.
Another way is to increase the coefficient of friction on all trolleys. I saw this in the Azores Portugal with the ox carts. By not greasing the axles they reduced the need for brakes.
In engineering we call that dampening.
The speed of 3.6 inches per second is not very fast but the load inertia is huge.
If you have to position these trolleys accurately you could also use a stop block at each trolley. a lever or solenoid operated gate that blocks the trolley from rolling into the next one. This would work in conjunction with the winch stopping and perhaps a short free roll to reduce the inertia.
Spring bumpers on the stop blocks would be advisable due to the large load.
I offer a service writing for people. I can present your documents in proper English if you like. www.writeforu.com
I am a retired engineer.
Re: Inertial Force
02/28/2011 2:32 PM
Friction coeff. is not something you can rely on being stable. It will vary on both predictable and random factors. When designing one should concider worst case scenarios. I wouldn't think for such a construction with more than 25 Joules k. energy on each trolley and no braking capability for starters.
Re: Inertial Force
03/02/2011 8:54 AM
Thank you guys..
thanks alot for guiding me..
Register to Reply 10 comments
Anonymous Poster (2); Just an Engineer (1); merc600sec (1); nick name (1); TonyS (2); yuvarajsukumaran (3)
