Previous in Forum: Alcohol Fuels & Greenhouse Gasses   Next in Forum: Creating low temperatures
13 comments
South Africa - Member - New Member
High boiling point liquid
04/04/2007 5:32 AM
Hi everyone, We are using a Glycol pulsation rig to test Radiators, condensers and hoses where Glycol (mixed with water to a certain ratio, usually 50:50 or 70:30) is the testing liquid. The problem we are experiencing is that the mixture begins to boil when the temperature exceeds approximately 115 degrees celsius. We are attempting to achieve a temperature of 130 degrees C. Do you have any recommendations as to achieve this i.e. a new working fluid etc higher boiling point(150 degrees C or more)?
Re: High boiling point liquid
04/04/2007 6:14 AM
It would help if you could explain why 130 C is important. Is this a safety requirement, a mandatory requirement? There are substances with greater boiling points but none I can think of that are going to be suitable for you usage.
There's them that knows and them that just thinks they know, whitch are you? Stir the pot and see what rises up. I have catalytic properties I get a reaction going.
04/04/2007 11:43 AM
If the system being tested can contain pressures in excess of 1.7BarG, one could use dihydrogen monoxide.
http://www.simetric.co.uk/si_steam.htm
04/04/2007 3:53 PM
Is that a posh chemists way of saying water?
Good Answers: 16
04/04/2007 11:11 PM
Mercury is a liquid that meets your boiling point requirements. It is extra heavy and mercury vapour is toxic. It may not indicate the leaks as well as water, if that is what you are trying to do, as it has a different viscosity and molecular size.
Make it so.
Good Answers: 120
04/04/2007 11:36 PM
propylene glycol or dipropylene glycol will work and boil higher.
ethylene glycols are toxic, propylene glycols are not
http://www.raypak.com/afreeze.htm
http://www.chemicalland21.com/industrialchem/organic/DIPROPYLENE%20GLYCOL.htm
http://en.wikipedia.org/wiki/Diethylene_glycol
Per Ardua Ad Astra
Engineering Fields - Manufacturing Engineering - United Kingdom - Member - Get things done!
04/05/2007 2:51 AM
have you not heard of the DMRD (Dihydrogen Monoxide Research Division)?
Check this out for a moment of jolity.
http://www.dhmo.org/
'The truth is out there' The lies are in your head.
04/05/2007 9:25 PM
Yes I saw it some time ago but they watered down the facts.
04/04/2007 11:51 PM
The simplest way is to increase the pressure on closed systems with glycol:water mixtures.
Isn't this the real world application for such mixtures?
What are you testing for? Thermal failure? How about an oil or similar non-aqueous fluid?
04/05/2007 5:19 AM
I believe a silicon type liquid is available but expensive , its used in high temp. Baths for calibration of Temp. instruments like temp. switches. What about vegetable cooking oils?
INDI-LINK makes 'Light' of 'Current' events, a veritable window into wiring.
04/05/2007 7:46 AM
Mbhele,
You do not say what radiators you are testing but you do say Durban.Could it be the Toyota plant or the old smiths.Knowing more would assist me as I do this in the radiator field every day.A 15lbs pressure cap would get your water to a higher temp and then a mixture of prop and water 50:50 might get it close.Toyota use the nippy or small pressure cap 13lbs or .9kpa so I am not aware of any manufacture that makes a nippy with a higher pressure.As you are doing the pulse testing why not use air pressure to get to the high pressure.I am very interested in why you want 130 deg would you give me an idea.
best
robert ferreiro
robert_sagoo@africaonline.co.ke
04/05/2007 11:16 AM
Glycerin water mixtures are higher boiling and do not seem to break down as fast as the glycols. I am assuming you are using a buffer and anticorrosive in your current mix.
04/05/2007 12:47 PM
if you intend to utilize 'antifreeze' solution --ethylene glycol and water--which you probably do since those are the actual service fluids and have a low surface tension, then using a 70% EG, 30% water mixture, AND 15 PSIG system pressure will allow temperatures above 265F before any boiling. I believe your target temp of 130C is about 266F. You cannot achieve this temperature with any EG:water solution without the 15 PSIG system pressure.
Keith E Bowers, PMP
04/28/2007 10:59 PM
How many gal. do you need?
I have heat transfer oil. Air Craft Quality.
Tom Silver
800 862 4328 Monday
Register to Reply 13 comments
Anonymous Poster (2); aurizon (1); BlueAussieBoy (1); BrainWave (3); docrobgar (1); fliptop427 (1); Keith E Bowers (1); PlbMak (1); PWSlack (1); Stirling Stan (1)
