Previous in Forum: High Impedance Relay   Next in Forum: Power Supply
Shaft Voltage Measurement
02/28/2011 5:23 AM
Is shaft voltage measurement test applicable for horizontal motors only?
Are impulse test & surge withstands tests are applicable for HT motors?
Anand Kathale
Good Answers: 53
Re: Shaft voltage measurement
02/28/2011 6:23 AM
I am not talking on behalf of any standard but if in my application motor is mounted vertical ,I ll check it for vertical first regardless of what standard say.
Re: Shaft Voltage Measurement
07/18/2011 1:47 PM
Dear Mr. anand.kathale,
The answer is NO for both items referred by you.
Thanks,
RAJESWARI.
Register to Reply 2 comments
You might be interested in: Line-shaft Spools, DC Motors, Stepper Motors
