Previous in Forum: Water Levels Versus Mechanical Levels   Next in Forum: Loading combinations TIA/EIA-222-F vs TIA-222-G
Asphalt vs Spray Seal
02/28/2011 11:12 PM
Hello, What is the difference between asphalt and spray seal? From application, construction & pros/cons point of view?
Re: Asphalt vs Spray Seal
02/28/2011 11:29 PM
Asphalt is used to construct roads, parking lots and other surfaces that must be thick enough to support the weight of vehicles.
Spray seal is what you put on old asphalt to make it last longer.
There is no comparison between the two. Totally different materials/applications.
Reply to Forum Thread
