Previous in Forum: Gap Inbetween Metal And Lining.   Next in Forum: KVAR & KWH
GPR UTILITY Leak DETECTION
03/01/2011 3:56 AM
Hi
I need help on determining the exact equipments needed to conduct a leakage test on buried natural gas pipelines using GPR (Ground Penetrating Radar) utility.
I'd appreciate any help on this matter!
thanks
Good Answers: 58
Re: GPR UTILITY Leak DETECTION
03/01/2011 4:45 PM
maryko
I have no experience with this. Unless someone else can help, try Google and enter "ground penetrating radar equipment"
Good Luck!
03/02/2011 3:05 PM
While I am not sure of the exact equipments needed, I would certainly say you need equipments that WILL NOT make any sparks!
Can equipments be had that is intrinsically safe? If yes, start there.
In addition: ¡SIN FUMAR! RAUCHEN VERBOTEN! NO SMOKING!
Register to Reply 2 comments
