Previous in Forum: Safety vector for lifting electric hoist   Next in Forum: Olympian Diesel Generator
12 comments
Filling of Tank
03/01/2011 8:12 AM
hi,Please tell me how to find the velocity of the flow from the hole which is made at the mid height of the tank when the water is poured continuously to the tank.Because once the water level reached the hole the water starts flowing out through this hole also.Assume that the flow rate of water pouring into the tank is known.which drives the velocity through the hole? In case of emptying the tank with water level initially at 'h' height from the bottom hole the velocity will be found from sqrt(2gh).here the driving force is the pressure head!
Re: Filling of Tank
03/01/2011 9:17 AM
Too many variables, too little information.
Make the hole big enough and the flow coming out will be the same as the flow going in.
Good Answers: 53
Re: Filling of Tank
03/01/2011 9:46 AM
Velocity will be constant at the point, when rate of change of water level due to inflow = rate of change of water level due to outflow, when it will happen? will depend on the construction of outlet hole, size of outlet hole and amount of friction at outlet, and may be few more factors, This is the point when outlet and inlet flow will equalise, You can also get a constant flow at outlet if tank start overflowing.
Mathematics? sorry!!
Re: Filling of Tank
03/01/2011 10:08 AM
When outlet is submerged, the flow will behave as a submerged oriface.
When partially submerged, you have weir-flow.
When not submerged, you have no-flow.
Is the tank vented? Diameter? etc.?, etc.?
Re: Filling of Tank
03/01/2011 10:51 AM
Mind if I use this. "When not submerged, you have no-flow" I think it"s very funny when thinking of holes.
Re: Filling of Tank
03/01/2011 10:53 AM
Sure, use it. Chicks will love it!
Re: Filling of Tank
03/01/2011 12:02 PM
Not exactly what I had in mind.
Re: Filling of Tank
03/01/2011 12:35 PM
If you can tell me the flow rate and the size of the hole, I can calculate the average velocity. I specify "average velocity" because the velocity at the center of the hole will be greater than the velocity near the edge.
Re: Filling of Tank
03/04/2011 4:00 AM
i just want to know the approach to find this.so please take your own values for the variables.
Re: Filling of Tank
03/04/2011 5:20 AM
Yeah, I did that in post #1
Good Answers: 67
Re: Filling of Tank
03/02/2011 3:51 AM
To me it appears like a student homework, for which this forum is not meant.
Re: Filling of Tank
03/02/2011 4:56 AM
No. If it was homework, there would be enough information to answer the question.
Popular Science - Cosmology - New Member Engineering Fields - Civil Engineering - New Member Engineering Fields - Nuclear Engineering - New Member United States - Member - New Member
Good Answers: 38
Re: Filling of Tank
03/02/2011 2:43 PM
Using control volume analysis and applying the law of conservation of mass I ended up with a differential equation (contains both a function of "h" (tank elevation above the hole) and its derivative). The bad news is that I don't think it is solvable (I'll keep investigating though), so I doubt you will find a function for the velocity.
Sometimes my thoughts are in a degree of order so high even I don't get it...
Register to Reply 12 comments
Anonymous Poster (3); ChaoticIntellect (1); lyn (2); pritam (1); raj (1); rakesh_semwal (1); Randall (1); user-deleted-1105 (2)
