Previous in Forum: 2000 Chevy Cavalier 2.2 - Turns Over but Won't Start   Next in Forum: Supercharger
8 comments
Shorted KV
03/02/2011 9:17 PM
Hi,
I'm working in a painting company, wherein we are using ABB robotics for spraying/painting automotive parts. The matter that I need information is that whenever we are painting and applying highly metallic color (like silver) the KV are being shorted out thus resulting in poor application of paint (mottling) or no wrapping of paint on the other side of the parts.
Once the KV is shorted out the feedback from the fiber optics cable to the display are zero, we have been doing a lot of evaluation but still no positive result yet. We already contacted ABB but still looking for some definite answer. Does anyone have experience on this? Any help would be highly appreciated.
Re: Shorted KV
03/02/2011 10:26 PM
If KV = kilovolts (??), this must be rather entertaining.
Re: Shorted KV
03/03/2011 12:19 AM
Or terrifying. One of my favorite videos.
Re: Shorted KV
03/03/2011 6:24 PM
Yes it is kilovolts.
Re: Shorted KV
03/03/2011 2:45 PM
Are you doing some form of EPD?
Sounds like your pieces may not be conductive, or you are not cleaning the conveyer well, thus losing the ground connection.
Some paints have a fairly high amount of chromium; that might have something to do with it, but I would tend to think not.
Re: Shorted KV
03/03/2011 6:33 PM
Thanks for your reply, were not using EPD, as what i've said we are spraying paint using ABB robotics which are computer assisted painting. We are painting plastic parts for automotive and supplying all ACURA and Honda models including Cadillac and Buick which are all high end cars. Our line are conveyor type, where in maintaining the grounding are always high priority as the plant has hired a cleaning company where they do cleaning every end of the shift.
The shorting of KV happened only on metallic color not on solid color like white, red, black, yellow etc. any idea on this.
Re: Shorted KV
03/04/2011 12:14 AM
Only that you should check the seals between the painting area and where the High Voltage resides. Without knowing at all the spacial geometries and barriers of the electrodes and the paint spray I cannot hazard any more of a guess. It seems I have to ask the obvious question though. If the high voltage is not used in EPD to attract the paint droplets, what is it doing in a painting area?
Good Answers: 21
Re: Shorted KV
03/04/2011 6:36 AM
Is the material being applied water born or solvent? Water born has a tendency to allow shorting of components much more easily as you can imagine. But, I also wounder why you have the high voltage in this location, when its is not needed to transfer droplets to substrate.
Good Answers: 58
Re: Shorted KV
03/04/2011 7:09 AM
If I had to make a guess, it would be that metallic paints produce small airborne conductive particles that short out your KV and result in a fireworks display. Isolating the source of these particles from the KV with a good filter might improve your operation.
Register to Reply 8 comments
Doorman (1); fixitorelse (1); pinoy (2); redfred (2); Tornado (1); welderman (1)
