Previous in Forum: Higher Rated Voltage Motor With Low Voltage VFD   Next in Forum: Cable Size for 355 KW 3 Phase Induction Motor
Relation Between Energy Efficiency Grade and Electromotor Efficiency
03/03/2011 4:20 AM
hi to all
i'm new on cr4
i want to know is there any relation between energy efficiency grade of electromotor and it's efficiency?
if yes what is the relation or formula?
Re: Relation Between Energy Efficiency Grade and Electromotor Efficiency
03/03/2011 9:59 AM
Hi, Welcome.
There is no formula.
The higher(better) the EER (energy efficiency rating) the more efficient the motor will be. This rating is acheived by testing the electrical device.
03/04/2011 2:09 AM
CAN WE ORDER IT WHEN WE ARE ORDERING THE ELECTROMOTOR ?
DO THE MANUFACTUERE KHNOWS IT FOR A MANUFACTURED MOTOR?
03/04/2011 2:44 AM
welcome!
just take a telephone call to the manufacturers to inquire all your questions...
"make the best better"
03/07/2011 2:04 AM
manufacturer dosnot know it. i'm searching for a way to calculate it from electromotor charactristics and test reports. tnx
03/04/2011 8:07 AM
Most motor manufacturers offer energy efficient motors. These motors produce the same shaft output as older models, but use less energy.
03/08/2011 11:50 AM
....only do turn off Caps Lock first.
Register to Reply 6 comments
e.rose (2); lyn (2); PWSlack (1); vicqui (1)
