Previous in Forum: Supercharger   Next in Forum: Parallel Parking or Bay Parking?
c240 maf sensor
03/03/2011 10:24 AM
i have a 2003 c240 mercedes...had it for 2 yrs...no major problems..only done oil change..new tires and maintenance..couple of days ago ..was stopped at light..stepped on gas and didnt move...car was idle ing ...not going at all..turned the car off for about 10 minutes...retsarted and car worked fine..and a few minutes later the check engine light came on..according to codes...it was the MAF sensor...had that put in new..all codes removed and all ok..and worked fine out of dealer..next morning get into car and drove about 5 miles and CEL came on..what could this be???
please help!!!!!!!
Re: c240 maf sensor
03/03/2011 10:33 AM
So, when the CEL reported trouble after you replaced the MAF sensor, what was the trouble code? It may very well be a different problem.
Re: c240 maf sensor
03/03/2011 10:42 AM
8 years old is kind of middle aged for most cars today, particularly a Mercedes. It is a bit unusual for anyone, particularly a Mercedes owner, to be doing their own repairs and troubleshooting. You have a fine pedigree vehicle that seems to me to be just starting to show its age. What could be next, almost anything or nothing.
Re: c240 maf sensor
03/03/2011 12:43 PM
ACTUALLY...YES THE CAR HAS BEEN A REALLY GREAT CAR...NO COMPLAINTS TILL NOW..AFTER HAVING OWNED A CORVETTE THAT GAVE ME SENSOR PROBLEMS EVERY WEEK ...I LEARNED THAT ITS BETTER TO KNOW WHAT THE CODES ARE TELLING YOU BEFORE YOU TAKE IT TO A DEALER WHERE THEY CHARGE YOU FOR THINGS IT DOESNT REALLY NEED.. THANKS
Re: c240 maf sensor
03/04/2011 11:02 AM
Soooo,
If you interrogate the car today, what trouble codes does it give you?
Re: c240 maf sensor
03/05/2011 5:00 AM
Have you tried to google it ?
http://www.google.co.uk/search?q=CEL+on+2003+c240+mercedes&sourceid=ie7&rls=com.microsoft:en-US&ie=utf8&oe=utf8&rlz=1I7ADFA_en&redir_esc=&ei=CQlyTbHeOszHsgb74YmEDg
found these for you to look at i havent checked them i will leave that for you to do
could it have been the air intake pipe is loose or air being sucked in between maf and inlet manifold ie air leak
Doorman (2); NORMAJEAN26 (1); redfred (1); still ere (1)
