I have a hydraulic system which will be in an underwater application, and I need some verification of my estimates considering that I don't have a good feel if my results are reasonable.
Here are the conditions:
2" pipe Sched 10 carbon steel (assume unpainted)
The pipe is horizontal
Oil Presure : 125 psi
Oil flowing in pipe: Royal Purple 46
Oil Temperature entering pipe: 70'C
Oil flowrate: 43 gpm
Saltwater Temp: 35'C
saltwater pressure: 107 psi
Saltwater conditions: still (to be conservative)
Pipe Length: 5m
Can anyone run the calc to verify the following:
1) What will be the approximate outlet temperature of the oil at the end of the pipe?
2) What will the heat loss be in Watts over the length of the pipe be?
Thanks in advance.
