i am doing project on bearing cup wat i need is how much force
is required for each stage (i.e forging sequence) and how much depth it
will travel for each punch force please help
Project description:
bearing cup:
material :1045 steel cold drawn
final component : OD=20mm of depth 20mm and inner dia of 14mm
and depth of 14mm actually this cup is done by impact extrusion and
volume of the component is 4099mm3 and i calculated backward extrusion
force=400KN
initial billet:OD=20mm and height 13mm here the press used is knuckle joint press of 650ton capacity
