Previous in Forum: 11 KV Motor Capacitor   Next in Forum: Earth Fault And Earth Leakage
Project Topic
03/04/2011 2:53 PM
Can any body advice me on what project topic to pick. I am a final year student of electrical/computer engineering. thanks
Re: PROJECT TOPIC
03/04/2011 3:18 PM
Good Answers: 181
Re: PROJECT TOPIC
03/04/2011 5:48 PM
This may sound totally alien to you but have you tried thinking for youself?
Good Answers: 130
Re: PROJECT TOPIC
03/05/2011 6:30 AM
Re: PROJECT TOPIC
03/07/2011 4:25 AM
thanks for all the comments, i'll definately find them useful.
New Zealand - Member - Kiwi
Good Answers: 29
Re: Project Topic
03/05/2011 4:04 PM
OK, I have a suggestion for something that might prove interesting and will teach you a whole lot of interesting stuff :
We commonly use a heater-based thermal overload relay to protect a 3-phase induction motor. These typically use heating elements wound around bi-metallic strips as the sensing elements.
In recent times, we see the major manufacturers producing electronic versions of the same devices.
Your mission, should you choose to accept it, is to design, construct and test a block of software code that provides the functions of a thermal overload relay. The way that I had thought to do this is to write a block of code for a PLC that could be formatted into a function block so that it could be re-used. The function block would have 3 analogue inputs derived from CT's, plus any other discrete inputs needed to make it work.
FWIW, I am told by various gurus that this plan is not likely to produce a viable alternative to the humble thermal overload relay due to reliability issues. It will, however, teach you more about software modelling of induction motors than you could ever need to know.
All the best with your studies.
paulusgnome
Re: Project Topic
03/06/2011 1:03 PM
What course? Is this a two year certificate level course, a four year degree, postgraduate, masters, doctorate (yes we had someone asking a similar question doing his final year doctorate).
What are your interests and what level of complexity does your project need to be?
Re: Project Topic
03/08/2011 11:47 AM
Would you like fries with that? Ketchup?
Register to Reply 7 comments
34point5 (1); Anonymous Poster (1); isiyakuyusuf (1); jack of all trades (1); lyn (1); Paulusgnome (1); TonyS (1)
