Previous in Forum: Polyethylene Pellets Upgrading   Next in Forum: Pumps in Parallel
Laser Welding of Brass
03/07/2011 10:01 AM
Hello all
We have pulsed Nd:YAG laser system having frequency range up to 100Hz, Pulse width from 0.2ms to 20ms, average power 350W and Pulse energy 80J. The focus lens having focal length of 75mm. We are trying to weld Brass having thickness 1mm. We are not getting welding results and our protective mirrors are damaging. Kindly guide the following:
1- What are the best parameters to weld Brass?
2- How we can protect the protecting mirror or focus lens?
Good Answers: 120
Re: Laser Welding of Brass
03/07/2011 11:04 PM
Metallurgical Considerations: Some metals cannot be laser welded due to their metallurgical
composition. Brass, for example cannot be laser welded. Why? Brass is an alloy of copper and
zinc. The problem with brass is that the melting temperature of the copper (1084C) exceeds the
boiling (vaporization) point of the zinc (907C). Zinc melts at 419C. By the time the copper melts
the zinc has vaporized. When the zinc vaporizes it explodes and splatters metal over a large
area. The same is true with bronze and phosphor bronze
Per Ardua Ad Astra
08/04/2011 10:37 AM
Interesting answer, based on your assumptions it would be impossible to produce the alloy brass, as all the zinc would vapourise in the furnace. I have succesfully had samples produced, with stranded copper wire laser weded to brass contact tags.
This used a pulsed Yag machine designed for jewelery welding. the machine has binoculars and the operator holds the parts to be welded under the aiming spot and operates the laser by foot switch.
Good Answers: 120
08/04/2011 10:47 AM
Pulsed welding is the way to go, it avoids sustained temperatures on the zinc. I would expect the making of bulk alloys would proceed by adding the higher boiling metal to a vat of the melted - dropping copper lumps into stirred molten zinc for example, so they dissolve to the desired alloy point. A molten surface flux might also be used.
Per Ardua Ad Astra
Good Answers: 58
03/08/2011 8:14 AM
Aurizon is correct. However, there are some things you can do to increase your odds.1) use longer pulses. Greater than 5 ms is recommended to obtain penetration and reduce the temperature gradient. 2) de-focus slightly to improve beam homogeneity. 3) A gas jet can be used to prevent vaporized zinc from condensing on the objective lens. Good ventilation is required.
Register to Reply 4 comments
aurizon (2); John Wood (1); welderman (1)
