Previous in Forum: Moisture Content in Gasohol   Next in Forum: Hydrogenator
Removing Oxidized Paint
03/07/2011 3:54 PM
I'm looking for a particular oxidized paint remover. Years ago I worked part-time as an automotive detailer. I used a product from a company called Geo Polishing to remove oxidized paint. The product worked extremely well. It would remove only the oxidized paint and leave the intact paint. I would then put on a protective sealer. I used the stuff to remove years of built-up oxidized paint and it would leave a shiney surface ready for a wax/sealer. I've looked on the internet for references for the company but I've found nothing.
Does anyone have any information on the company, or another quality product?
Thanks,
Don
The only people who don't make mistakes are those who don't try.
Re: Removing oxidized paint
03/07/2011 4:14 PM
Sounds like rubbing compound.
Unless some mystical need for specific performance, any good quality rubbing compound should do it. The link is to 3M (not an endorsement).
03/07/2011 5:34 PM
Thanks for your comment but the product I used utilized a chemical process, not a physical one like a rubbing compound. This stuff, no matter how hard or long it was used, would only remove the oxidized paint and not harm (scratch) the still good paint.
Re: Removing Oxidized Paint
03/07/2011 7:58 PM
I stumbled on Mr. Clean Eraser sponges with soapy water, they don't last very long but are very surprising. run a light spay hose as you scrub to wash off excess. sounds too simple but it worked for me.
Engineering Fields - Electrical Engineering - New Member Engineering Fields - Mechanical Engineering - New Member
03/07/2011 10:44 PM
nice info
One system
Good Answers: 16
03/08/2011 12:26 AM
Don't know the product you are searching for but most cars now have a clear coat over the color coat (paint) so the color coat doesn't oxidize. OEM clear coats by and large stand up for a long time without breaking down (not so for aftermarket low buck paint jobs). Most clear coats are plastic resins so it will take a pretty harsh solvent to remove them.
03/08/2011 9:05 AM
Yea, I understand about the clear coat and the paint underneath not oxidizing. I was looking for something to clean up paint on an old vehicle. I didn't want to use the standard rubbing or polishing compound because the abrasives will scratch and remove the good paint along with the oxidized paint. I'll keep looking. Thanks.
Register to Reply 6 comments
Don in LA (2); Doorman (1); Graycav (1); loadshare (1); setho (1)
