Previous in Forum: Recommend Books for Instr. Engineering Calculations   Next in Forum: CE Certification
15 comments
Fluke Repair
03/09/2011 11:49 AM
Ok so I'm going out on a limb here but its all I have left as Fluke wont help me because they say they offer technical support on repairs...and the service centers have not been able to help me either.
I have a 718 30G out of warranty, it wouldn't hold pressure. So i sent to a service centre for them to tell me it could be the pump diaphragm but they were not sure and it would cost close to $1000 to take the chance. I said to hell with that I'll find the problem myself, so after taking the unit apart I found that it clearly was not the pump diaphragm it was a small nozzle that feed the pressure from the pump into the sensor assembly. Whats happened is the glue or adhesive used to attached said nozzle onto the sensor has dried up and the piece had fallen causing all the air to leak whenever the pump was pushed.
Bottom line I'm trying to find out if anyone knows what kind of glue/adhesive is used to attach such a piece onto the back of this sensor which is located directly on the circuit board, I know it will take some steady hands to glue this back on to prevent plugging on the sensor input.
So if anyone knows of any sort of glue for this application please let me know it would be appreciated.
Thanks
cems
Re: Fluke Repair
03/09/2011 12:22 PM
What specific materials are involved? Metals? Plastics? Maybe a picture?
You will find that everyone has a favorite adhesive that's "the best one out there".
Fact is, there are many adhesives which will work.
Epoxies, cyanoacrylates silicones all might work. More details please.
Re: Fluke Repair
03/09/2011 12:31 PM
It would really help to advise if we had a picture:
  1. Take a picture and get it on your hard drive.
  2. Start another thread like you started this one.
  3. Type your question.
  4. Click the button above.
  5. Click Browse.
  6. Find the picture file and click Open.
  7. Click Submit.
Knowing the materials of the nozzle and sensor body would help as well.
Re: Fluke Repair
03/09/2011 12:40 PM
Overview
Where the piece needs to attach.
How it should look...
The piece that needs to be re-affixed.
As for the material of the piece it appears to be some sort of metal, exactly what I'm not sure.
Hope that can give some more insight in.
Thanks,
cems
Re: Fluke Repair
03/09/2011 12:59 PM
Thanks, cems,
A couple more questions:
Is the face of the sensor plastic? Looks like it might be polyethylene.
What is the max pressure of the module?
Like Lyn says there are a lot of different ones that will work, but will depend on the answer to these as well.
Re: Fluke Repair
03/09/2011 1:06 PM
It looks to me like the pressure range on the sensor input is -12 to 30psi, it also lists the max NDT pressure @ 60 psi.
From the feel of the sensor I wouldnt say its plastic by any means, feels almost chalky to the touch similar to the edges of the board itself. Not having a lot of experience with PCB's or anything similar its tough for me to say.
cems
Re: Fluke Repair
03/09/2011 1:21 PM
I probably would us a two part epoxy that is rated for a variety of materials - something like this. (disclaimer)
Lay as even a bead as you can in a circle on the face of the sensor, concentric with the hole, but stay away from the hole; you don't want to use too much either so as not to plug the hole.
Good Luck!
Mike
Re: Fluke Repair
03/09/2011 1:24 PM
"Looks like it might be polyethylene."
Or acetal, polyester, Nylon, etc. Could be anything, that's the problem.
I'd be inclined to suggest a cyanoacrylate from the hobby shop. Something "designed" for adhesion to thermoplastics. It was attached at one time, probably with a CA adhesive in production quantities applied by a robot. I'd just apply a very thin bead around the outside of the metal part and put it back in place. After that cures, you might want to apply a small bead around the outside of the metal part for added sealing. Breathe on the exposed "glue", it likes moisture to cure.
Good Luck.
Location: "Springwood", North Tamborine Mountain. Qld. OZ.
Re: Fluke Repair
03/10/2011 4:01 AM
Really with the othre guys here, but, I'd try a really small bead of hotmelt.
Quickly! Carefully!
Cheers,
Stu.
"Nothing, is as it seems." Dr Wally.
Re: Fluke Repair
03/10/2011 10:30 AM
Thanks for the help guys I'm going to attempt this fix in the near future and hopefully she works...
cems
Re: Fluke Repair
03/10/2011 10:37 AM
Well,
True to form, you have gotten three different opinions on how to repair this. I'm skeptical of the hot melt, frankly, because of the delicate nature of the repair and the fact that one part is metal.
Whatever you use, be sure to clean the two pieces with alcohol. Nothing stronger, since we don't know what type of plastic we're dealing with.
Please let us know what you use and how the repair went.
Good Luck, don't glue your fingers together.
Re: Fluke Repair
03/10/2011 1:18 PM
Excellent advice. I would have said exactly the same if I'd thought of it.
Re: Fluke Repair
03/10/2011 1:52 PM
Diligent cleaning is probably more important than choice of adhesives, in most cases.
Re: Fluke Repair
03/10/2011 3:01 PM
Yup!
Re: Fluke Repair
03/10/2011 10:41 AM
Oh I'm not planning to use hot melt...the sensing element is quite thin I dont want to apply any sort of heat to it.
cems
Engineering Fields - Electrical Engineering - New Member United States - Member - New Member
Re: Fluke Repair
03/14/2011 8:27 AM
Any chance on finding a source for the sensor? I guess I would try to repair it first, but if that fails, time to look for a part number on the sensor, and see if there is any sources for that. Fluke had to buy it from someone. Down side to sensor replacement might be calibration of the unit, it probably is dependant on the sensor, and a new one would mean re-cal would be in order.
Tom D.
Register to Reply 15 comments
cems (4); lyn (4); Mikerho (5); Stueywright (1); tdesmit (1)
