Dear All,
I have a UV vacuum Ionizer install in our machine, which act as a static discharge for the substrate in the sputtering chamber.
As the unit do not come with the running hour timer, and I can not keep track of the usage of the UV bulb.
The UV light output intensity reduce over time, in order to keep the maximum machine performance, I would like to look for a UV light metering equipment, appreciate if anyone can recommend me such measuring equipment.
UV Wavelength range : 115 to 400 nm.
Thanks
Moi
